diyAudio Sponsor
Old 23rd October 2011, 06:18 AM   #1
Default EL86 / 6CW5 + 6BQ7A amp design
Hi. I am from Brazil, and i am newbie on tube amps.
I am trying to design a PP amp with EL86 power tubes + 6BQ7A pre / inverter with "18W Marshall Lite Style."
Can someone check this schematic to see if there is something wrong? The voltage chart was estimated.
Thanks a lot.
Old 23rd October 2011, 07:02 AM   #2
Miles Prower's Avatar
Thanks a lot.
I take it this is supposed to be a push-pull design? One final doesn't even have a signal applied to it. It's just hanging there, doing nothing. If you want the finals to self-split, you need a substantial (preferably a CCS) tail load, and you have none.
Four sections of two 6BQ7s in cascade is going to give way more gain than you'll need here, especially if you aren't using gNFB.
6BQ7s aren't the best type to use here either.
Either the design is badly messed up, or the schemo is.
There are no foxes in atheistholes
www.dolphin-hsl.com
Old 23rd October 2011, 08:05 AM   #3
Do you really need two volume pots?
tubes.rs
facebook.com/tubes.rs
Old 23rd October 2011, 08:50 AM   #4
Cookj is offline Cookj  Belgium
There is a phase splitter:-
33k Anode load
Cathode 2k2 + 33k to gnd, 820k Bias, 10n cap coupled
Old 23rd October 2011, 08:55 AM   #5
Blaireau's Avatar
33k Anode load
Right! But a quick redraw of the schematics would make it easier to understand at first glance.
http://constructions.f6fkn.com
Old 23rd October 2011, 09:18 AM   #6
Yvesm is offline Yvesm  France
Yvesm's Avatar
Miles was probably at the end of a long day
And it's obviously a guitar amplifier, that justifies the large gain and the two volume contols
Nevertheless, it should work, go for build it !
Old 23rd October 2011, 02:21 PM   #7
Blaireau's Avatar
By the way, 25W with a couple of EL86... The designer was not really pessimistic!
Old 23rd October 2011, 03:01 PM   #8
davorin is offline davorin  Croatia
You need coupling capacitor(5-33nF) between plate of 3rd triode and 2nd volume pot.
Old 23rd October 2011, 03:06 PM   #9
Yes, 25W is possible, but must rise first 32uF(68uF or more!) in HV-filter, and remuve 180ohm/5W, or substitute with much lower value (10-50ohms).
Old 23rd October 2011, 03:13 PM   #10
33k Anode load
Sorry for the poor design. It is my first, i tried to make the things easy to me.
The inverter is there, a little hide, i admit, but it is there... It will work???
My biggest doubt is about the value of the resistors on power supply. I need 250V to the plate, but 200V to the screen. 8k2 + 1K is good enough to decrease 50V at that point? Zero-signal screen current = 4mA and maximum-signal screen current = 23mA (G&E datasheet).
The problem is... i have a LOT (more than 500 pieces) 6BQA7A... So, i want to use them.
And yes... the ideia is a guitar amp "18W Marshall Lite Style". The first volume is the gain control.
Good to know that i will have too much gain... Decrease gain is the easy part. I was afraid about do not have it... 6BQ7A has a Mu of only 35, less than a 12AV7.
I used the data on G&E datasheet... 25W for a pair of EL86 in PP...
But a good advertising is all.
Ps. My english is not so good. Sorry if i made any mistake.
anyone ever use el86/6cw5? mctavish Tubes / Valves 17 22nd July 2011 11:02 AM
25W with 2xEL86(6CW5)! davorin Tubes / Valves 22 6th October 2010 07:24 AM
EL86 / 6CW5 availability for Simple P-P? hartze11 Tubelab 1 27th May 2010 03:16 AM
Spice model for EL86/6CW5 genome Tubes / Valves 0 17th October 2005 02:49 PM
Subbing EL86 (6CW5) for EL84 andyjevans Tubes / Valves 6 28th May 2005 06:13 AM
Page generated in 0.10239 seconds (82.71% PHP - 17.29% MySQL) with 11 queries
