diyAudio Sponsor
Old 23rd October 2011, 12:16 AM   #1
Default Western Electric theater amplifiers; how to hook them up?
Hello all, new here.
I just came across a pair of IPC (Western Electric design) AM-1001 power amps. They've been dormant since the mid 1980s and I'm itching to give them a try. However, all my experience with tube amps has been with guitar gear and these are a different animal. It's a bit over my head to wire them up.
Each amp has a terminal strip with these positions:
Input
GND
RVC (four terminals)
FIL (two terminals)
OUTPUT
PLATE
MON+
In addition, they have the AC/common power leads. How would one wire this to a modern preamp output and a loudspeaker? I have the matching crossover network but I'll probably just hook to a modern full range speaker for now. Thanks all!
Old 24th October 2011, 02:57 PM   #2
Here's some pictures of what I'm talking about if that helps...
Old 24th October 2011, 03:06 PM   #3
Pano is offline Pano  United States
Pano's Avatar
Thanks for the pic. Those amps are highly coveted, you have a nice find!
There should be someone here who can help. You'll want to power those up slowly, like with a variac or light bulb in series trick.
I'm very curious as to why the plate and filament are brought out to panel connections. Perhaps to power the preamp?
Take the Speaker Voltage Test!
Old 24th October 2011, 03:11 PM   #4
Yep, was planning on using a Variac... these were in a theater that closed in 1986, so they've been sitting at least that long.
I was wondering if those plate/fil connections were for the preamp. Maybe they are superfluous for using the amps by themselves? A bit out of my realm of experience. Thanks!
Old 24th October 2011, 03:21 PM   #5
Pano's Avatar
You're welcome. If you don't get an answer here (not likely) then we can try over on the Altec forum.
It's a little scary to think that the B+ voltage could be sitting there on the a screw terminal.
Old 24th October 2011, 03:41 PM   #6
martyh is offline martyh  United States
RVC is remote volume control, jumper 1-2 and 3-4
Connect input + to input and – to ground
Connect speaker between output and ground
Mon + and plate are DC and Fil is 6.3Vac for other parts of the system
Look here for the manual and schematic under C60 sound system
Film-Tech
Note the networks on the feedback loop for adjusting HF and LF
Old 24th October 2011, 03:51 PM   #7
Trout is offline Trout  United States
Trout's Avatar
I hope you are going to replace that gassed tube before powering up.
Old 24th October 2011, 03:55 PM   #8
Pano's Avatar
Excellent! Here is a direct link to the manual:
http://www.film-tech.com/warehouse/m...SIMPLEXC60.pdf
The schematic appears on page 35.
Old 24th October 2011, 04:00 PM   #9
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
yup - that most left tube is dude
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
Old 24th October 2011, 04:02 PM   #10
Pano's Avatar
What's new set of matched 6L6? About $50?
Western Electric plant kmaier Tubes / Valves 8 28th October 2008 08:54 AM
Western Electric 374A john Tubes / Valves 4 21st December 2005 03:17 PM
Western Electric 300B serengetiplains Tubes / Valves 4 16th December 2004 06:16 PM
Western Electric transformer contaxchen Swap Meet 0 22nd March 2004 02:54 AM
Western Electric PassFan Tubes / Valves 0 26th April 2003 01:09 PM
Page generated in 0.09753 seconds (77.76% PHP - 22.24% MySQL) with 10 queries
