diyAudio Sponsor
Old 21st October 2011, 03:45 PM   #1
cs is offline cs  United Kingdom
Default Best sounding ECC83 ?
What is the best sounding modern version of the ECC83 (for HiFi use) out of the following manufacturers :
Golden Dragon
Ei Elite
Svetlana
JJ
Old 21st October 2011, 04:12 PM   #2
Yvesm is offline Yvesm  France
Yvesm's Avatar
The best sounding tube is the one that doesn't sound at all.
That said, what you hear has more to do with the way you use the tube than with the tube itself . . .
Old 21st October 2011, 04:20 PM   #3
Zoran is offline Zoran  Serbia
I had very good experience from newer types of ecc83
with
Sovtek 12AX7-LPS
cheers
Old 21st October 2011, 04:32 PM   #4
For HIFI, I'd say any 6SL7 you can find. =)
Old 21st October 2011, 05:02 PM   #5
ECC83, 12AX7 are not for HiFi.....but for guitar ampl!
Old 21st October 2011, 05:03 PM   #6
piero7 is offline piero7  Italy
piero7's Avatar
the blackburn ones
Old 21st October 2011, 05:17 PM   #7
Alastair E's Avatar
Absolutely!
ECC83, Horrible tube IMHO!
Change the Socket and use summit Nice instead!
Das Beste Oder Nichts
Old 21st October 2011, 05:28 PM   #8
SY's Avatar
It's a tricky tube to use, but used correctly, it's incredibly linear. I've posted data on this previously.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 21st October 2011, 06:36 PM   #9
There is no "best sound" for any tube. Various ECC83/12AX7 tubes have different sound characteristics, while different people prefer different sound characteristics.
The Sovtek 12AX7-LPS have exceptional details in the mid-high frequencies.
NOS Telefunken have much "body" in the mid-high frequencies.
Old 21st October 2011, 06:50 PM   #10
SY's Avatar
Really? No matter what the circuit they're used in, where the branded tubes originated, or when they were made (and hence internal structure)? Telefunkens have quite different structures depending on when and where they were made- the shape of the ink printed on the tube doesn't give them a common electrical characteristic.
Bride of Zen using ECC83 renjiish Pass Labs 15 16th November 2007 02:38 PM
best value/performance ECC83 on market richwalters Tubes / Valves 20 7th October 2007 10:41 PM
Pinout ECC83 to ECC808 donramon14 Tubes / Valves 1 10th January 2007 07:32 PM
Which ECC83 tube and caps question wuffer Tubes / Valves 4 14th September 2005 07:21 PM
Mullard ECC83/M8137 david3565 Tubes / Valves 0 16th December 2001 07:15 PM
Page generated in 0.09735 seconds (75.70% PHP - 24.30% MySQL) with 11 queries
