| diyAudio Sponsor | ||
#11 |
I have a good audiobuddy who has been using mercury rectifiers for several years and the system he has built sounds fantastic.
A few points from his experience: The ones he uses are thyratrons connected as diodes. You must heat the filament before applying high voltage, the mercury must be ionized first or else the rectifier will be damaged. He has not experienced the commonly mentioned problem of high frequency "hash" noise in practice. They are extremely beautiful. Email me and I can put you in touch with him, alternatively, make a post at Audio Asylum in the Tube DIY forum with "Mercury Rectifier" in the heading and I am 100% sure he will see it. -j |
#12 |
The best way to neutralize mercury is to put sulphur on it. The mercury will react with it rather than with your lungs.
| Tannoy mercury Mk2 | cmitch | Multi-Way | 2 | 2nd February 2009 04:45 AM |
| Mercury Vapour rectifiers | Craig405 | Tubes / Valves | 16 | 14th February 2006 03:34 AM |
| Mercury Magnetics | Andrewbee | Tubes / Valves | 3 | 29th May 2005 03:21 AM |
| Using 866A Mercury Vapour Rectifiers? | SHiFTY | Tubes / Valves | 18 | 28th January 2005 03:29 AM |
| Page generated in 0.08977 seconds (53.67% PHP - 46.33% MySQL) with 10 queries |
