Using low voltage lamp in power supply
Old 21st October 2011, 01:14 PM   #21
EddieRich is offline EddieRich  United States
EddieRich's Avatar
This is only a design at this point. I connected the transformer to the line and measured the voltage on the secondary. The circuit will only draw 90mA, so I can't imagine it's going to drop 20V. That would be a 12% drop.
I'm going to use an RCRC filter instead of the lamp, for reasons explained above. I'll measure everything once it's built and if the voltage is that far off, I'll change the 'R'.
Old 21st October 2011, 01:32 PM   #22
Tom Bavis is offline Tom Bavis
Tom Bavis's Avatar
Measure the DC resistance of the windings and the unloaded secondary voltage and I can model it - so can you - download PSU Designer from Duncanamps.com. Voltage drop will be more than you think, since the transformer current has a high peak-to-average value. For instance, a 50VA isolation transformer (10 Ohm primary and secondary, good for 0.4A RMS) will have a drop of about 14V from no load to 90 mA DC. Transformer secondary current about 160 mA RMS, 550 mA peak.
Old 21st October 2011, 02:01 PM   #23
Pano is online now Pano  United States
Pano's Avatar
I agree. PSUD is a great tool. It will do a lot of the work for you before you start soldering or choosing values.
Using low voltage lamp in power supplyHide this!Advertise here!
Precision Adjustable Low Voltage DC Power Supply Stocker Equipment & Tools 0 19th December 2010 05:44 AM
Joule Thief - LED low voltage Power supply - With pictures vr4 Everything Else 7 12th February 2009 12:49 PM
Low Voltage High Power Supply thndr Power Supplies 4 2nd February 2008 12:33 PM
Low Voltage Plate Follower 6DJ8 Buffer Power Supply mwl6m Tubes / Valves 50 3rd August 2007 07:50 AM
Low Voltage (+70V) Power Supply Design mwl6m Power Supplies 43 1st August 2007 01:00 PM
