| diyAudio Sponsor | ||
hello dear "audio"friends...I managed to do this...since this is my first post on this forum....I can hardly wait your opinions...remarks etc
#2 |
I put here the original schematic that I used...with the following modifications: V1,2 V3,4=6N6P(russian) Ua=400V R2=18k/1w,R6=12k/1w,I also added a trim pot(20K) on the anode of V3,4 for simetry of the signal...now the most important part..I used one pair of GU50/channel,so the OT(output trafo) becames Raa=6k4 5000 windings of CuEm=0,25 and secondary 189 windings of 0,6CuEm you can see in the attachment...I used 28Cm2 instead of 24Cm2
#3 |
Nise, and good documentation.
How does it sound? |
#4 |
#5 |
Tinkerer
All well and good, but you didnt show the real schematic yet, just a generic one...
Also, I am sure it will not play very well on top of your loudspeaker. |
#6 |
#7 |
Data viitoare sa specifici in titlu ca amplificatorul este PP , ca sa nu mai piarda vremea cu subiectul tau......( into Romanian )
Next time you specify in the title as the amplifier is PP not to spend time with your subject ...... |
#8 | |
Nise, and good documentation. How does it sound?" He understands....see? Last edited by gedd; 21st October 2011 at 09:55 AM. |
#9 |
Tinkerer
I downloaded everything. All I saw was a 1955 Mullard schematic, a schematic from your final stage, without driver, and 4 PCB layouts. Now I do not know what Gimp saw, but am I supposed to trace the PCB's to see how is your circuit wired???
| Building new GU-50 stereo amp... | Wavebourn | Tubes / Valves | 129 | 4th August 2011 04:26 PM |
| GU-50, GM70 and KT88 | nina | Tubes / Valves | 39 | 24th June 2010 06:09 PM |
| GU 50 output modification | beamnet | Tubes / Valves | 22 | 15th January 2010 03:02 PM |
| Use of 12j1l and gu-50 tubes | gemby | Tubes / Valves | 6 | 26th October 2008 09:56 PM |
| GU-50 output trafo | croccodillo | Tubes / Valves | 7 | 11th May 2007 08:55 AM |
| Page generated in 0.11013 seconds (75.66% PHP - 24.34% MySQL) with 11 queries |
