| diyAudio Sponsor | ||
Hello,
I am looking for the formula that calculates the driver stage minimum quiescent current requirement regarding the following stage (triode or pentode) Thanks in advance ! Eric (France) |
#2 |
The quiscent current is determined by the charging current of the input (Miller) capacitance of the output stage at the highest frequency at the highest amplitude sinusodal signal possible at the grid of the output stage.
#3 |
which translates into ?
#4 |
You asked for a formula. Here it is:
I >> A Cag 2 pi f Vpk where I is quiescent current A is voltage gain of next stage Cag is anode-grid capacitance (valve plus holder plus strays) f is highest signal frequency Vpk is peak signal voltage at grid of next stage Strictly, the input and Miller capacitance should be Cgk+(A+1)Cag but ACag is close enough in most cases. You only need a rough estimate, as you then need to exceed it by a decent margin. |
#5 |
I = C * (dU/dt)
#6 | |
#7 |
>> means much greater than. I would say a factor of 2 or 3 in this case.
> means greater than, so a factor of 1.01 would satisfy that. |
#8 |
For example 300B requires (almost) 2mA pp grid current at 20kHz (220V pp driving, A2 mode).
#9 |
If I try for a 45 tube :
Cag = 7uuF Cgf = Cgk = 4uuF Amplification factor (A) = 3.5 ppV = class A1 centre value cathode bias * 2 = 100v f = 20.000 Hz C=Cgk+(A+1)Cag = 35.5 uuF I = 3.5 * 35.5x10^-12 * 2 * 3.14159 * 100 * 20000 = 0.0015613 = 1.56 mA Right ? |
#10 |
| how to calculate current requirement | chicago_mike | Tubes / Valves | 9 | 3rd January 2009 04:13 AM |
| Please help a newbie with PSU current requirement for Aikido linestage | ncc | Tubes / Valves | 1 | 24th September 2007 03:34 PM |
| Output Inductor Power Requirement | gearheadgene | Class D | 6 | 28th February 2007 03:47 PM |
| Power supply requirement help | araven | Power Supplies | 1 | 8th August 2006 07:26 PM |
| Minimum power requirement | Seville | Multi-Way | 3 | 3rd December 2001 01:15 PM |
| Page generated in 0.09227 seconds (76.79% PHP - 23.21% MySQL) with 10 queries |
