diyAudio Sponsor
Old 17th October 2011, 08:26 AM   #1
Default 6c33c-b question
Steve Bench had an article about using a power triode in inverted operation. I was wondering if the 6c33c could be used in inverted
mode and what the grid power rating would be in this case.
Old 17th October 2011, 08:43 AM   #2
piano3 is offline piano3  United Kingdom
He uses 6AS7 so why not?
Old 18th October 2011, 04:01 PM   #3
Mordor is offline Mordor  Italy
another stupid question: im making a simple se 6c33 ampl. ive founded this data: http://www.jogis-roehrenbude.de/Russ...atasheetMB.pdf but i cant find anywhere how see tube for identify pin.... from botton or from top ? Anyone can help me ? p.s. im making this: Click the image to open in full size.
thank to all
Old 18th October 2011, 04:56 PM   #4
Data sheet shows allways the bottom view.
Old 18th October 2011, 05:02 PM   #5
kevinkr's Avatar
The plate is connected to the largest pin in the middle and the diagrams are viewed from the bottom. (Verified on 6C41C) It has been a long time since I had any of 6C33 tubes on hand so I can't check directly, but that is the convention the 6C41C follows..
www.mif.pg.gda.pl/homepages/frank/sheets/113/6/6S33S.pdf
In any case just look at the tube to make sure that you have not swapped the grid and cathode connections - this tube is so large that the connections are obvious when you look at it.
www.kta-hifi.net
Old 18th October 2011, 05:17 PM   #6
thank you so much, another: in this schematic i can found some strange resistor, like 10w 400 ohm resistor on 6c33... i found a near value... why this chose in your opinion ?
Old 18th October 2011, 05:23 PM   #7
kevinkr's Avatar
That is the cathode bias resistor which sets the operating point of the output stage. What is the close value you found, anything within a few % ought to be fine. Based on my recent (and unrelated) issues with failing WW resistors I would use at least a 50W resistor there. (It may be dissipating 15W or more if the plate current is close to the claimed 200mA.) I'd use one of those chassis mounted aluminum housed power resistors: http://documents.tycoelectronics.com..._1773035_B.pdf Something similar to this..
www.kta-hifi.net
Old 18th October 2011, 05:25 PM   #8
410 ohm 12 w parallel of 2 820
Old 18th October 2011, 05:33 PM   #9
kevinkr's Avatar
That would work, but as indicated the dissipation is pretty high..
www.kta-hifi.net
Old 19th October 2011, 06:48 AM   #10
another, im giving 12.6 vac at filament in series with a transformer. Can i connect the middle of series of heaters to audio star gnd in order to elimiate some noise?
6C33C & Borbely Question dannydanger Tubes / Valves 0 25th August 2010 05:54 PM
How to get the best out of the 6C33C-B? knightsound Tubes / Valves 11 21st July 2010 08:50 PM
6c33c-b & 6c33c-v skybird Tubes / Valves 4 21st April 2009 06:21 AM
6C33C-EB / 6C33C-EV extended life ? ger56 Tubes / Valves 2 14th October 2007 05:54 PM
6c33c Question woody Tubes / Valves 1 17th May 2002 12:01 PM
Page generated in 0.09429 seconds (79.88% PHP - 20.12% MySQL) with 10 queries
