diyAudio Sponsor
Old 17th October 2011, 02:53 AM   #1
kenben is offline kenben  United States
Default 1st project salvaged sears receiver iron need good amp schematic
I have a sears receiver with a 12ax7 and 6bq5 se it has 295 b+ . after looking around on the net. I am thinking that the OPT are probably smaller than most of the amp I have seen and was wondering if any one has advice on what’s best to build with these parts ? would like to run out put pentode mode. Thank you
Old 17th October 2011, 03:51 AM   #2
TheGimp is offline TheGimp  United States
TheGimp's Avatar
It would be helpful if you could find the original model number and a schematic.
Off the hand, I'd recommend Baby Huey.
EL84 Amp - Baby Huey
It is a long thread, but well worth reading as it is quite educational.
Old 17th October 2011, 04:32 AM   #3
aardvarkash10's Avatar
Single-ended? RH84.
Yes, conservatism thrives on low intelligence and poor information. But the liberals in politics... continue to back off, yielding to the supremacy of the stupid. It's turkeys all the way down. - George Monbiot, guardian.co.uk, 6 Feb 2012
Old 17th October 2011, 04:33 AM   #4
I have looked but no luck on finding it. It is a single ended amp with one 12 ax7 ½ for each channel and one 6bq5 for each cannel was going to pull the transformers and make a small power amp doesn’t’ have to be same design that it is just something that sounds good. It’s a receiver so it should have more power than it needs from the power supply just powering a power amp. Thanks for your response Gimp
Old 17th October 2011, 04:38 AM   #5
rh84 probable has much bigger OPT would that make a diferance if i just kept the volume down or would i have to change other values
thanks
Old 17th October 2011, 04:50 AM   #6
the standard opts will be fine - one of the distinctions of the RH is its tolerance of a wide range of opts. Otherwise, just follow the schematic.
Old 17th October 2011, 04:57 AM   #7
Thanks I’ll order some parts tomorrow
What is a good 1st order Good Band pass? chico1st Chip Amps 1 21st May 2011 04:30 PM
1st Post (here) : ) My first project: Boozhound Amp bottom_feeder Tubes / Valves 95 25th June 2010 01:39 AM
Silvertone (Sears) stereo amp percy Tubes / Valves 20 24th August 2007 03:25 AM
1st Project & a ? philipbarrett Full Range 1 14th November 2005 04:11 PM
looking for 1st timer amp project to power adire kit 281s wotan2525 Chip Amps 6 21st July 2003 11:45 AM
Page generated in 0.09959 seconds (77.92% PHP - 22.08% MySQL) with 10 queries
