diyAudio Sponsor
Old 16th October 2011, 06:36 PM   #1
harley is offline harley  United States
Default simple EL84 parallel?
Anyone tried extending the power output of the simple EL84 with CCS by paralleling the output valves (2 to 4 or more)?
Also, I've not seen clear documentation of what the output power of this amp is. I think it is about 10W, is that right?
Old 16th October 2011, 07:29 PM   #2
vinylkid58's Avatar
Cathode bias pentode should get to 12W. Tubelab?
jeff
Old 16th October 2011, 09:13 PM   #3
aardvarkash10's Avatar
in practise, probably less in the simple (self splitting output) design. 8 to 10-ish watts.
Yes, conservatism thrives on low intelligence and poor information. But the liberals in politics... continue to back off, yielding to the supremacy of the stupid. It's turkeys all the way down. - George Monbiot, guardian.co.uk, 6 Feb 2012
Old 16th October 2011, 11:17 PM   #4
so no attempts I take it?
Old 17th October 2011, 01:55 AM   #5
ArtG is offline ArtG  United States
With Dave Gillespie's EFB bias mod, a Dynaco ST35 (EL84 PP, UL) will produce 17.2 watts per channel from 20Hz to 20KHz both channels driven) at a maximum of 1.7% distortion at 20Hz (much lower at higher frequencies).
A recent post on this forum "Doubling the power of hifi tube amplifiers" shows the impressive result of doubling the output tubes of an Eico amplifier that utilizes 7591 outputs.
The techniques discussed in this article could be, and should be applicable to an EL84 amplifier, although I don't believe that anyone has yet tried it.
If you are willing to experiment with this technique, there could be some worthwhile gains possible.
Old 22nd October 2011, 09:12 PM   #6
what about using an LM317 CCS for each tube? Would that not be better than the EFB bias mod?
Old 23rd October 2011, 03:27 AM   #7
rmyauck is offline rmyauck  Canada
Dave Gillespie mentions that LM317 CCS doesn't work well in his articles. Check diytube for lot's of info. Extra tubes should double power, but you would have to change resistor value for cathode bias, plus use a output transformer with half the primary impedance. EFB mod should work too and give all the benefits. You can then keep the dissipation below 12W for use of many different tubes and long life if you set them at 27 mA ea.
parallel pp EL84 civic2006 Tubes / Valves 3 6th June 2010 03:08 PM
EL84 and 6V6 in parallel??? youngb4 Tubes / Valves 102 13th May 2010 11:38 PM
parallel EL84 transconductance amp nesha Tubes / Valves 6 11th November 2007 08:51 AM
seeking: tube for a SEP parallel feed like an EL84, but with a lower Ra aletheian Tubes / Valves 30 17th November 2005 04:24 AM
Parallel PP EL84 and ouput transformer question corbato Tubes / Valves 7 6th January 2003 01:26 PM
Page generated in 0.08766 seconds (75.65% PHP - 24.35% MySQL) with 10 queries
