| diyAudio Sponsor | ||
Hi all!
Long ago I started building this amplifier after reading here on diyaudio.com. I also bought a set of speaker units from kimj2000 that I build cabinets for I am very exited about my first real stereo tube amplifier setup on original speakers from the good times. I have totally fallen in love with the bass sound the EL34 deliver. Enjoy it! Amplifier: 2x30W EL34 tube amplifier | Kaizer Power Electronics Speakers: Isophon BS35 loudspeakers | Kaizer Power Electronics
http://www.kaizerpowerelectronics.dk |
#2 |
Can you provide some test results of the amplifier ?
Would be interesting to see some. |
#3 |
Some pictures would be very nice, too.
#4 | |
There is loads of pictures and some video if you follow the links, now that I already had it uploaded on my own site, I didn't want to upload and arrange it all once again here
#5 |
Is there no edit post button?
What I meant to say was: I only got to set bias and DC balance, I have no distortionmeter for setting AC balance and I am not sure I succeeded with the other methods Claus described in his paper. So till I have the amplifier correctly adjusted, I won't do measurements on it. But I do also lack all the exotic equipment to do a full test on it. Can it be done with a tone generator and a oscilliscope?
| EL34, Claus Byrith amplifier, mains noise problem | MadsKaizer | Tubes / Valves | 9 | 12th August 2011 02:26 PM |
| Finished EL34 tube amp... but oscilates weird.. | TubeManiac | Tubes / Valves | 9 | 4th May 2011 06:37 AM |
| PSU Caps for an EL34 SET | audio_moksha | Tubes / Valves | 7 | 5th January 2007 05:54 PM |
| Simple EL34 SET; advice? | audio_moksha | Tubes / Valves | 11 | 29th November 2006 03:58 AM |
| My El34 SET | alexmoose | Tubes / Valves | 10 | 9th May 2006 08:10 PM |
| Page generated in 0.08382 seconds (74.48% PHP - 25.52% MySQL) with 10 queries |
