diyAudio Sponsor
Old 15th October 2011, 09:54 PM   #1
Default Cathode bypass with Long tail pair
Hopefully a quick question. With a long tail pair, 12AX7, 82k plate resistors, 620 ohm cathode, 33k tail, would there be much effect by having the 620 ohms capacitor bypassed?
Old 15th October 2011, 09:57 PM   #2
SY's Avatar
More gain, but you'll need very large bypasses if you want to extend that gain into the bass.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 15th October 2011, 10:32 PM   #3
22uF, are we talking about the same gain increase as you would get in a single stage? I do not recall seeing it used before, not that I get around all that much.
Old 25th October 2011, 12:48 AM   #4
Hate to second guess the only reply I got but I thought about this a bit more and am a little confused. I should have thought more on it earlier rather just before I wire up the circuit but better late than never.
Thinking this through I get the feeling that if I put a capacitor on the cathode resistor in a Long Tailed Pair inverter I would not get any signal in the second triode. I see the LTP as a self-split output stage that needs a ac voltage developed across the cathode resistor in order for the second triode to have a signal to amplify. By using a bypass capacitor the gain on the first triode is increased but the second triode grid and cathode is at the same potential as each other and you would not get any signal on the plate.
If someone can ease my mind over this I would appreciate it.
Old 25th October 2011, 09:55 AM   #5
Merlinb is offline Merlinb  United Kingdom
If you bypass the bias resistor you will get fractionally higher input impedance (assuming an AC coupled circuit), but apart from that there is very little to be gained; the tail resistor still dominates the performance.
Old 25th October 2011, 10:46 PM   #6
That is good to know. I am trying a switched PI (cathodyne, paraphrase, LTP) and did not want to switch out the capacitor when using LTP but wanted it for the other two modes. Thanks.
And since you are partly to blame for me wanting to try it...
http://i406.photobucket.com/albums/p...uckAmp17-1.jpg
How to bias Long tail pair....?? RRITESH Solid State 83 15th August 2011 05:20 PM
Long-tail pair phase splitter sdinfo Tubes / Valves 14 21st September 2010 12:35 AM
Long Tail Pair Linearizer Electrone Solid State 17 21st April 2009 02:25 PM
5687 long tail pair NickC Tubes / Valves 7 14th May 2002 01:04 PM
Page generated in 0.09872 seconds (76.39% PHP - 23.61% MySQL) with 10 queries
