diyAudio Sponsor
Old 15th October 2011, 08:11 PM   #11
boywonder's Avatar
Here's a link from Elliott Sound Products on how to measure it; it's quite easy. You'll need a PC based sine wave generator (I'm sure that you can find free software) if you don't have a function generator. The function generator will come in handy when testing an amp if you modify or build one also.
If you are testing with a power amp (no volume control) make sure that you have a means of attenuating the signal so you don't blow your head off (or your speakers).
Measuring Loudspeaker Driver Parameters
Tube amps like a well behaved impedance plot, not too many dips & peaks from 20-20Khz, the flatter the better. There will be an impedance peak at driver/system resonance.
Old 16th October 2011, 12:23 AM   #12
Unfortunately, a full plot is needed to find where the minimum impedance lies. Most likely, it will be in the lower midrange or bass regions.
Paul Joppa has provided us with a useful rule of thumb. Joppa's rule states, for a "typical" listening space, an amp speaker combo should be capable of producing 102 dB. SPL peaks at a 1 M. distance.
It's beginning to look like 30 WPC, minimum, is what's needed. Mullard style circuitry using Soviet surplus 6П3С-Е (6p3s-e) O/P tubes or an "El Cheapo Grande" (7591 "finals") are possibilities. Acquiring suitable magnetics, without busting the $450 or thereabouts budget, is going to be key. For example, the well thought of English firm of Sowter charges £173.67 each for their suitable model UA21 O/P transformer. A pair of those would leave little for all the other parts.
Building a decent amp within budget is easy enough. Building a decent amp that mates with the KEF speakers and not spending too much is a challenge.
Eli D.
AMD tube integrated tube amp ivegotmono Tubes / Valves 1 18th December 2008 07:32 PM
Remote control for integrated tube amp Driller99 Tubes / Valves 3 4th May 2008 06:15 AM
Adcom integrated/tube amp project ben62670 Tubes / Valves 13 30th January 2008 06:58 PM
pre out on a integrated tube amp? ume Tubes / Valves 1 13th March 2006 02:51 PM
New computer motherboard with integrated tube amp ThingyNess Everything Else 17 5th June 2002 07:12 PM
Page generated in 0.07236 seconds (72.45% PHP - 27.55% MySQL) with 10 queries
