diyAudio Sponsor
Old 14th October 2011, 05:16 PM   #1
Default Audio Note Kits L1 Build...
Received my EL84 tube integrated L1 kit from Brian Smith of Audio Note Kits Canada this week--only regret is the lack of time to build. Nevertheless, wow, what a nice package! All high quality parts very well packaged and well laid out. Can't wait to get to the listening point.
For now, I have populated all the resistors on the 3 mm PC board.
Thought you all DIYers would like to look over my shoulder as I build it.
WHALEMAN
The Cathedral Speaker Co.
Old 14th October 2011, 05:25 PM   #2
Cassiel is online now Cassiel  Greenland
Cassiel's Avatar
Well, not all but maybe some. I'd rather watch Columbo.
Old 14th October 2011, 05:43 PM   #3
You have permission
WHALEMAN
Old 14th October 2011, 06:03 PM   #4
Tinkerer
Stop trolling the innocent!
Old 15th October 2011, 02:15 AM   #5
OK, I was able to squeeze in putting on the tube sockets, nice gold plated pins, then had to go out for dinner.
Later the Rubycon electrolytics, then the silver micas, and the power supply components were installed.
Last were the venerated Mundorf M Cap Supreme couplers, $17 each, but well worth it.
Now the board is totally populated. Let see how far we get tomorrow.
WHALEMAN
Old 15th October 2011, 12:47 PM   #6
AndrewR is offline AndrewR  United Kingdom
Take your time, enjoy the build one bit at a time.
Andrew
Andrew Randle
The Hi-Fi Watcher
Old 15th October 2011, 01:29 PM   #7
Andrew
Yes, agree. My tendency is to want to rush through. I have to stop now and do something else.
Just wired the inputs:
WHALEMAN
Old 15th October 2011, 05:41 PM   #8
Thanks for the detailed pics!
It looks like the input cabling (between jacks and selector switch at front) is unshielded. Two 3-conductor cables (R,L) and a separate ground/common conductor?
Looking at a 'proven' design and layout like this one can be quite instructive.
Looks like a nice kit, though spendy. The output transformers are a big part of the value, I suppose.
And you do get a pro-looking finished project.
Keep those pics coming!
Old 16th October 2011, 02:31 AM   #9
Yes, unshielded individual silver plated copper teflon coated, six cables in white heat shrink. I decided to braid the rest since it looked like I had enough.
Here are more pictures showing progress. I like the binding posts that I normally use more, so I had to drill bigger holes for them! But worth the risk. Lots of metal on the floor, this is thick aluminum. No harm done...
Almost ready for the cover...more tomorrow.
WHALEMAN
Old 16th October 2011, 08:58 AM   #10
Tinkerer
I was under the impression that earth should shield the signal cable for lowest noise? Comments on that, guys?
Audio Note speaker kits: Anybody tried 'em? ultrakaz Multi-Way 10 14th January 2011 12:43 PM
Audio innovation L1 valve replacement phimor Tubes / Valves 3 13th September 2006 10:22 AM
FS: Audio Note TRANS-010; Audio Note 20H 50mA choke; Black Gate Wk "power tank" Joseph0 Swap Meet 1 24th May 2006 05:17 AM
Audio Note P-2 Yurik Tubes / Valves 0 26th February 2004 11:11 PM
Audio Note Kageki vs. EAR 859 vs. Audio Innovations: The First Vortex Tubes / Valves 1 2nd February 2004 12:31 AM
Page generated in 0.11402 seconds (83.68% PHP - 16.32% MySQL) with 11 queries
