Any info on a Trio AF-220 tuner? Any info on a Trio AF-220 tuner? - diyAudio
Old 5th September 2003, 06:57 PM   #1
Hewie is offline Hewie
Send a message via AIM to Hewie Send a message via Yahoo to Hewie
Default Any info on a Trio AF-220 tuner?
I fell into a Trio AF-220 tuner and am having troubles finding any info, can anybody help me? I contacted Kenwood, but they don't have anything in their archives, and searches on the net don't lead to anything. Anyone know where to track down a schematic for this or something similar. The tubes are as follows: 2 x 12AT7, 4 x 6BA6, 1 x 6BE6, 1 x 6AU6, 1 x 6AL5, 1 x 6X4.
There are 5 outputs and they have me stumped as well labeled as follow: (0 = OUTPUT)
AM.FM.MX_____AM.MX________FM
____0____________0____________0________0______0
Monaural_______Right__________LEFT______MX ADAPTER
Did these units have real stereo as well as multipled stereo? And why did they do that?
One channel has low output and a heavy buzz, so I plan on trying to trouble shoot it, but is it worth it for this unit or does it belong in the parts bin?
Thanks for any insight.
Dave
Old 6th September 2003, 04:54 PM   #2
Tom Bavis is offline Tom Bavis
Tom Bavis's Avatar
These earlier ones often needed a separate multiplex adapter if you wanted stereo. Sounds like the case here. Left channel may not connect to anything without it. Use it for mono, or (good luck) look for a multiplex adapter. Most any brand would work, even a solid state one.
Old 6th September 2003, 09:00 PM   #3
EC8010 is offline EC8010  United Kingdom
diyAudio Moderator Emeritus
EC8010's Avatar
Default GE/Zenith
The MPX outputs will be before de-emphasis. You need a GE/Zenith stereo decoder. FM stereo is transmitted by sending L+R as the mono signal and sending L-R on a Double SideBand Suppressed Carrier (amplitude modulation) at 38kHz. A 19kHz pilot tone is transmitted which is used to regenerate the carrier required for demodulation of the DSBSC. Once L-R have been recovered, they can be matrixed with L+R to produce L and R individually, and finally have de-emphasis applied.
There used to be all manner of chips available to do this (MC1310 was an early one). Fixing your hum problem is probably just a matter of replacing dried-out power supply electrolytics. Decoders are commonly available in the UK for retro-fitting to Leak Troughline tuners that had indifferent decoders.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Any info on a Trio AF-220 tuner?Hide this!Advertise here!
Trio (Kenwood) DP-1000, Any info? GJF Digital Source 63 9th October 2013 09:48 AM
Seeking info: researching the Trio Kenwood L-07D for a magazine article Triophile Analogue Source 4 9th August 2009 05:42 AM
Kenwood (Trio) KW100T Vacuum Tube AM/FM Tuner Scott Novak Swap Meet 1 7th August 2009 06:12 AM
Larsholt fm tuner front end for JLH tuner design-Any still available? djsb Analogue Source 0 25th December 2008 04:46 PM
Modify Sat Tuner for Audio - Why no info fmak Digital Source 0 12th March 2006 01:53 PM
Copyright ©1999-2017 diyAudio
