| diyAudio Sponsor | ||
How much current or VA do I need from iso transformer to power 4x50L6s and 3x6SN7s & 1x50y6?
#2 | |
Also, post the schematic for your amplifier, please. BTW, you might consider contacting a moderator to delete your duplicate post on this topic. |
#3 |
Let me know where the dup thread is and I'll remove it.. One thread should be enough...
Edit: Never mind, found it...
www.kta-hifi.net |
#4 |
Virtual-
You really need to get used to coming back to your original thread and posting a 'Reply'.....please don't keep hitting the 'New thread' button! Anyway, you said: How much current or VA do I need from iso transformer to power 4x50L6s and 3x6SN7s & 1x50y6? 50L6 .15A filament Max plate dis 10W 50y6 .15A filament Max plate current 450ma 6SN6 .60A filament Max Plate dis 2.5W This is a very rough method: Work out the VA for the filaments first.... 50L6 4 x 0.15 x 50 etc then just use some approximate numbers to estimate the draw from the B+/HV side 50L6 say 50mA @200v... VA=.050 x 200 or just use the W ratings for the tubes 10W for 10VA, etc... etc Then multiply by a 'safety factor' to get an idea of the VA rating for your isolation transformer |
| PSUD Help Needed: What value do I enter for current? | bluegti | Tubes / Valves | 8 | 25th January 2010 12:30 AM |
| help needed on current control SMPS | jegandren | Power Supplies | 18 | 6th October 2008 02:28 PM |
| Current needed for switching a power FET switch | rtarbell | Parts | 0 | 22nd December 2006 11:17 PM |
| UCC208 current mode IC usage help NEEDED | Danko | Power Supplies | 15 | 22nd September 2005 02:22 AM |
| Current Mirror Explanation Needed. | vdi_nenna | Everything Else | 2 | 27th May 2001 12:23 PM |
| Page generated in 0.08433 seconds (75.10% PHP - 24.90% MySQL) with 10 queries |
