diyAudio Sponsor
Old 13th October 2011, 03:10 PM   #1
dewz is offline dewz  Armenia
Default Heater voltage 5volt!
Heater voltage 5v instead of 6.3. is not very critical?
Tube is 6n1 and 6p14
Thanks!
Old 13th October 2011, 03:24 PM   #2
DF96 is offline DF96  England
You might get lower noise and lower gain, also lower output. Possibly shorter valve life if too much cathode current is drawn.
Old 13th October 2011, 03:45 PM   #3
If your transformer has enough current you could rectify that 5V.
5 X 1.41 = 7.05 but you lose about a volt across the vectifiers so you would
get ~ 6V .
Old 13th October 2011, 04:06 PM   #4
kevinkr's Avatar
Rectify using schottky diodes in a bridge and you might get pretty close to 6.3VDC for your filaments. A big cap will be required to get the ripple down to reasonable levels and a pi filter using a low DCR inductor of a few mH might be worthwhile. Nothing worse than ripply DC for filament heating - far worse than AC because of the high dvdt of the ripple voltage - it couples electrostatically into anything nearby and blasts through the cathode insulation..
www.kta-hifi.net
heater voltage Bengali Tubes / Valves 8 2nd April 2011 06:21 PM
tube heater over voltage!please help... tubo Tubes / Valves 6 8th April 2009 11:58 AM
heater voltage Jaap Tubes / Valves 3 18th November 2008 11:39 PM
Need Help Setting Heater Voltage cgrums Tubes / Valves 10 25th January 2008 05:40 PM
Best way of reducing heater voltage? showdown Tubes / Valves 14 20th July 2006 07:15 PM
Page generated in 0.07034 seconds (74.23% PHP - 25.77% MySQL) with 10 queries
