diyAudio Sponsor
Old 12th October 2011, 02:29 AM   #1
G is offline G  United States
G's Avatar
Default To connect or not to connect..........
Hi all. I'm getting ready to start wiring up a parafeed preamp with transformers on the output and my question is simple. Do I connect the negative output of the output transformers to the negative rail or do I take it straight to the negative of the output RCA jack and leave it isolated? I have seen schematics with it both ways.
G
Gavin
Old 12th October 2011, 03:18 AM   #2
tomchr is offline tomchr  United States
tomchr's Avatar
I'm not a fan of floating windings as you never know what voltage they end up settling at. The differential voltage is controlled by the flux in the transformer, but the common-mode voltage is not. With parafeed it would take the failure of two components (coupling cap, transformer isolation) to get B+ on the output jacks so I guess you could argue it's "safe". I'd still recommend grounding the secondary for safety.
~Tom
"50 % of the game is mental and the other 50 % is being mental. I've got that part down, no problem."
http://www.neurochrome.com/audio
Old 12th October 2011, 11:04 PM   #3
G's Avatar
~Tom
Thank you for your reply. I will do just that.
G
Gavin
Old 13th October 2011, 01:49 AM   #4
Tom Bavis's Avatar
On the other hand, it's going to feed a grounded unbalanced input on a power amp, right? Keep it isolated and avoid ground loops. You can use a resistor from shell to ground - 100 Ohms or so. Actual ground will be at power amp input.
Old 13th October 2011, 08:55 AM   #5
Vinylsavor's Avatar
Hi!
There are advantages to both methods. grounding it at the peramp side can potentially cause a ground loop if preamp and power amp both have their grounds connected to safety earth.
On the other hand the secondary winding can develop a statuic charge when the peramp is unconnected. This will cause a loud plo if you connect the preamp to a power amp which is on.
A good compromise might be to connect the secondary through a resistor, say 47k to the ground in the preamp.
Best regards
Thomas
http://vinylsavor.blogspot.com/
How do I connect drclean Solid State 0 15th December 2008 06:03 PM
Where to connect shielding voivodata Tubes / Valves 1 30th March 2007 12:00 AM
How to connect a sub??? Klimon Subwoofers 6 19th June 2006 03:18 PM
HELP to connect a subwoofer cristiano Subwoofers 2 16th April 2004 02:14 PM
Page generated in 0.08094 seconds (75.24% PHP - 24.76% MySQL) with 10 queries
