diyAudio Sponsor
Old 11th October 2011, 02:23 AM   #1
Default Center tap transformer for elevated heater supplies
Hello,
Based on the power supply chapter in Morgan Jones' book, which is very similar to this one from a previous thread:
http://www.diyaudio.com/forums/attac...ply-supply.png
Can elevated heater supplies be used as shown for the LT section of the supply (at the above link) but with a center tapped transformer rather than the dual secondary as shown in the circuit. I know that dual positive supplies are possible but will the lack of isolation be problematic with the elevated heaters?
how to wire 6.3VDC heater on a heater with center tap (12.6V series, 6.3V parallel)? jarthel Tubes / Valves 9 14th April 2012 05:36 PM
How to do Single center tap/bridge regulated supplies? ChuckT Chip Amps 10 14th February 2008 02:23 PM
transformer with no center tap traw Parts 0 3rd June 2006 02:36 AM
center tap of heater winding dsavitsk Tubes / Valves 4 21st December 2005 04:40 PM
Transformer Center Tap dswiston Parts 2 4th February 2004 03:09 PM
Page generated in 0.06306 seconds (67.64% PHP - 32.36% MySQL) with 10 queries
