| diyAudio Sponsor | ||
Radiotron says the voltage gain of a power amplifier is 2.82*sqrt(Po*RL). Is this equation used all the time for power amp design, including push-pull?
#2 |
Which RDH? 4?
Which chapter, page, etc... |
#3 |
#4 |
sqrt(Po*RL) is a voltage, not a gain. The 2.82 factor makes it a peak-peak voltage for a sine wave signal.
#5 |
#6 |
This is the voltage gain of a triode output stage.
As DF96 pointed out, 2.82 is the factor from peak to RMS. The equation you gave is half the necessary information. It relates voltage gain M to power our when known along with the load resistance. The second formulae : M=(Emax-Emin)/2Ec1 defines the voltage gain as the ratio of the maximum output voltage divided by twice the input bias voltage on the grid, assuming an idealized condition where there is no grid current flowing at Vgk=0. From 1 & 2 you can equate output power to voltage gain if you know the load resistance by stating: 2.82 SQRT(PoRl)= M =(Emax-Emin)/2Ec1 Rearanging you get Po=((Emax-Emin)/2Ec1*2.82)^2)/Rl |
| Radiotron for sale | jlsem | Swap Meet | 8 | 12th June 2010 01:04 AM |
| Radiotron | Keithj | Swap Meet | 0 | 9th April 2007 04:55 AM |
| Radiotron Designers Handbook | Frazzled | Tubes / Valves | 15 | 26th March 2007 01:07 PM |
| RCA Radiotron 45s | Miles Prower | Vendor's Bazaar | 0 | 15th January 2007 09:30 PM |
| Cunningham/Radiotron RCA 58 | apassgear | Tubes / Valves | 2 | 1st February 2003 12:03 AM |
| Page generated in 0.08281 seconds (74.02% PHP - 25.98% MySQL) with 10 queries |
