diyAudio Sponsor
Old 10th October 2011, 02:59 PM   #1
airegin is offline airegin  Italy
Default suggested use for old telefunken tubes
hello, i found an handful of old used (untested) telefunken tubes: re034, re114 and re134.
any possible use for them as line stage or low powered amp ?
thanks!
Old 10th October 2011, 04:34 PM   #2
TheGimp is offline TheGimp  United States
TheGimp's Avatar
Probably so. How many of each do you have?
So far I found the re34, which is a direct heated small signal triode.
http://www.mif.pg.gda.pl/homepages/f...05/r/RE034.pdf
The re114 is a larger DHT good for 3W anode dissipation.
http://www.mif.pg.gda.pl/homepages/f...05/r/RE114.pdf
And the re134 appears to be similar:
http://www.mif.pg.gda.pl/homepages/f...05/r/RE134.pdf
Does anyone know what Durchgrafft is? My company German-English translation book gives me "inverse amplification factor, reciprocal of amplification". If this is a direct translation then the mu of the 114 is 5 and mu of the 134 would be 10, which might be reasonable.
Old 10th October 2011, 06:02 PM   #3
ChrisA is offline ChrisA  United States
Looks to me like a headphone amp.
Always the problem with building something from some tubes you happen to have is that (1) to use your free tube yu need to spend $100 on a transformers and (2) when the tubes needs to be repaced some years later you will not be able to find one.
You would need a low voltage transformer for the heater. Get 6.3V transformers and wire them back to back. Drop the 6.3 volts with a resistor. If you have 240V mains use a 6.3 and 12.6V transformer.
Old 10th October 2011, 06:15 PM   #4
Originally Posted by ChrisA View Post
when the tubes needs to be replaced some years later you will not be able to find one.
+1
Bad enough if it is still your amp, but do you really want it to end up as 'Grandpa's old amplifier that doesn't work any more"?
Old 10th October 2011, 06:22 PM   #5
put a scematic on the underside somewhere the heat wont come in a little plastic bag . note possible replacements . ( or just keep spares in a little compartment in the amp
use stuff that is available this stuf is antique sell it for a good sum whit buy now on ebay
netztrafo's pop up alot on local fleemarkets . find a standart peice of glasswhare and make something nice
Old 11th October 2011, 08:55 AM   #6
have just two of re114, but 4 of re134 and re034. seems that the maximum obtainable power output from the re134 is only 0,5W so i would prefer try them in a linestage rather than low power set amp. how can i revise my linestage (similar to http://www.dhtrob.com/schemas/afbeeldingen/vv227lun.gif) to try them ? thanks.
Old 1st November 2011, 03:12 PM   #7
tyo94 is offline tyo94  Indonesia
Send a message via Yahoo to tyo94
Hi airegin, the schematic which you showed actually for Indirect Heat tube, but works for Direct Heat Tube. You just need a few adjustment regarding Ra's and Rk's position.
Anyway let me know if you want to let go your tubes, I'll be glad to experiment with that kind of tubes....
Question regarding value of Telefunken tubes. thoriated Tubes / Valves 4 16th February 2011 11:49 PM
FS: Telefunken 12AX7 tubes xecluded Swap Meet 0 29th March 2010 01:29 AM
Some really old tubes, mostly Telefunken ilimzn Swap Meet 2 9th March 2009 03:33 PM
Telefunken tubes gianis Swap Meet 0 25th March 2008 10:58 PM
Suggested replacements for Chinese tubes chrisbp Tubes / Valves 11 20th October 2007 06:04 PM
Page generated in 0.08520 seconds (76.42% PHP - 23.58% MySQL) with 10 queries
