How to combine 2 signals from 2 gain stages
This is for a guitar amp input.
I will have 2 different gain stages, one a 12AX7 input and another a EF86 pentode input.
These are in parallel from the input but i need to be able to be continously variable on output. So, thinking of using a potentiometer. One end is triode, middle is pentode / triode mixed and other end of scale is pentode. Continously variable.
So how do i connect this on outputs of the triode and pentode? The following stage is another 12AX7, then tone and vol then output tube.
I also want to do this passively and not add another gain stage to combine the signals.
Thanks!
Then you reference the ouput of the slider to ground using say a 500K resistor?
Thinking about this though, as its set up one side or another cannot ever be at grond potential. Therefore there will always be some leakage from one to another.
so EF86 at say 125gain and 12AX7 at 70gain... just guessed on gains... both need say a 500K following stage load resistor.
Use a 250K pot for mixing and a 250K resistor to ground? of course cap couple before all of this.
make sense?
