100 V OPT
100 V OPT
Old 8th October 2011, 02:32 AM   #1
Hojvaelde is offline Hojvaelde  Denmark
Default 100 V OPT
Hey
I was up in landfills, where I bought a pair of used speakers in their hand shop.
The speakers are damaged but there was a transformer at each speaker box.
After I have googlet a little I found out it was 100 V types from PRO-signal.
I found a data sheet here: http://www.farnell.com/datasheets/483955.pdf type is PO38A.
How do I measure the primary impedance so I can use them in a little tube amp.
Benny
Old 8th October 2011, 04:54 AM   #2
trobbins is offline trobbins  Australia
trobbins's Avatar
This link may help:
Cheap Output Transformers
Old 8th October 2011, 06:58 AM   #3
artosalo is offline artosalo  Finland
artosalo's Avatar
What version ( power ) is your transformers ?
Try first to determine the turns (transforming-) ratios available with different primaries.
Feed a known AC-voltage, say 1 V and 1kHz in the 8 ohms secondary and read the voltages from all pirimary outputs and tell us.
Old 8th October 2011, 12:17 PM   #4
artosalo's Avatar
Let's calculate an example based on the specification you linked.
We know that there is constant voltage 100 V at the primary.
If we select the primary taps for 1.25 W and 8 ohms secondary.
We can now calculate the voltage across the secondary.
This is: U = √ P x R, which is √ 1,25 W x 8 ohms = 3,16 V.
Then we can determine the transforming ratio
= ( Uin / Uout) = 100 V / 3,16 V = 31,6.
The impedance ratio is 2 = 1000 and finally the reflected impedance from 8 ohms secondary to 1.25 W primary = 1000 x 8 ohms = 8 kilo ohms.
For 2.5 W primary, the reflected impedance is 4 k and for 5 W primary it is 2 k. etc.
Old 8th October 2011, 01:05 PM   #5
Yargh
Those 100 trafoes have a Zaa at only 1k. (8 ohm on 8 ohm tap)
The tabs are named Com, 40watt, 30watt, 20watt and 10watt.
Using 40 watt as B+ and COM and 10W for plate connections.
Are they useless or what
What tube can use so low impedance?
Benny
Old 8th October 2011, 02:55 PM   #6
hidnplayr is offline hidnplayr  Belgium
hidnplayr's Avatar
Use them in a circlotron
Real tubes have top-caps
Old 8th October 2011, 06:05 PM   #7
Printer2 is offline Printer2  Canada
Put a 16 ohm speaker on them and use a couple of EL86's for around 25W. Or double up the output and 50W into 8 ohms, going to need a 1:1 power transformer with a decent amount of current as the tubes run in the 170-250V range.
http://www.hifitubes.nl/weblog/wp-co...ctric-6cw5.pdf
Old 8th October 2011, 11:46 PM   #8
trobbins's Avatar
Benny, which part number do you have?
"Using 40 watt as B+ and COM and 10W for plate connections" - I think you may have misinterpreted the use of these line transformers.
Ciao, Tim
Old 9th October 2011, 12:47 AM   #9
Hi
I meant: Using "40 watt" tap as B+ and the two taps "COM" and "10Watt" as plate connections. This gives Raa at 1k and the impedance from B+ to "COM" and "10 Watt" are indentical.
Yes I know that they are not designed for use in tube amplifiers, but there are a number of articles showing that they can be used.
See the link in your first post. Unfortunately mine is not as useful as other types.
I have 15-20 used EL86/PL84 tubes. Then I can use a PPP solution to eleminate the low impedance.
Benny
Old 9th October 2011, 01:14 AM   #10
trobbins's Avatar
Appologies - I misinterpreted your post and thought you had a 5W tapping.
Philips made many PA amps using 6CM5/EL36 - they have a relatively low PP impedance requirement - which could probably allow 1k PP with B+ and screen around 200-230V, from a quick peruse of the datasheet. I have a restored quad 6CM5 amp, which worked out quite well.
Ciao, Tim
100 V OPTHide this!Advertise here!
Marshall EL34-100/100 Trepan Instruments and Amps 10 9th September 2017 04:39 PM
Bedini 100/100?? Need help to set bias sondguy Solid State 64 24th May 2016 12:11 AM
Electrocompaniet Ampliwire 100 (AW 100 AW100) different Versions tiefbassuebertr Solid State 5 25th December 2015 09:56 AM
Bedini 100/100 restoration. pauly99 Solid State 2 10th December 2013 10:10 AM
Bedini 100/100 Hum in one channel. UberRyan Solid State 3 14th April 2010 06:28 AM
