diyAudio Sponsor
Old 4th October 2011, 06:56 PM   #1
slor is offline slor  United States
Default Convert Gates pre-amp to DC filament?
I recently rebuilt / restored an old Gates "Dynamote" 2-channel mixer. They're really wonderful-sounding units but a tad noisy. I had hoped to convert this one to a quieter DC filament supply but I'm not sure that's possible with the current setup.
It's my dim understanding that to implement a regulated DC supply, you want the transformer to supply at least 3 "extra" volts to account for losses in rectification, filtering, and regulation. Right now the supply is at 6.6VAC, which is actually pretty good considering the transformer was designed to run on 115V.
Anyway, short of adding a dedicated filament transformer, is there any way to get there from here?
Many thanks in advance!
Old 4th October 2011, 07:27 PM   #2
Frank Berry's Avatar
I remember those mixers.
Is the noise 60Hz or 120Hz hum? Is it white noise?
Frank
Old 4th October 2011, 07:41 PM   #3
Hm, I hadn't actually thought to characterize it other than "tube noise."
By that I mean more hi-freq stuff than AC ripple. All the caps--filtering and coupling--are new. As you know, these units have REALLY high gain and compared with modern preamps, the noise floor is just a bit high. That's why I thought that a DC supply would be a useful mod....
Old 4th October 2011, 07:47 PM   #4
A DC supply will not improve the noise figure.
These mixers were designed for remote broadcasting 50 years ago.
Back then, noise wasn't that important. They were generally connected to equalized telephone lines.
You may be able to reduce the gain on the output stage and run the channel and master level controls higher.
Can you post the schematic for the program output amplifier?
Frank
Old 4th October 2011, 07:54 PM   #5
Here's the closest schematic I have, it's for a unit with remote gain control so the pots (1 for each input, and a master output) aren't shown....
Old 4th October 2011, 08:20 PM   #6
trobbins's Avatar
I agree that you need to understand what type of noise is of concern and where it may be being generated.
Noise from some resistor types may be an issue for olde amplifiers.
The impedance of C3 in the humdinger DC elevation may be relatively high, and not bypass heater coupled AC hum currents adequately. Similarly, some more hum reduction may come from increasing C3 in the first amp stage.
Grounding scheme and wiring dress may not have been optimum.
Capacitors were relatively costly and scarce back then - C2 could be significantly increased is size to pull B+ ripple voltage down.
Some techniques for localising noise are using a spectrum analyser of output waveform, along with an AC voltage meter with good low voltage resolution and mains earth loop rejection; battery powering the input valve heater; grounding the grid directly to cathode at the valve base of the first few amp stages.
Old 4th October 2011, 09:57 PM   #7
ChrisA is offline ChrisA  United States
No. The DC supply will not help the noise floor unless the problem is low frequency hum. You can prove this by using a 6V battery on the heaters and noting if the noise changes. Only if the 6V battery solves the problem, then go for DC heaters
Looking at the schematic I'd expect a lot of "tube noise" that is just the nature of pentode preamp tubes and this amp has it's share of those for sure.
Old 4th October 2011, 11:14 PM   #8
HollowState's Avatar
With three high gain pentodes in cascade I'm not surprised that you have noise. You might try the old trick that Hewlett-Packard and Boonton Electronics used in their old tube millivolt meters of starving the input tube 6V filaments by running them at 5 or even 4½ volts to reduce noise. They would also use selected low noise types like Telefunkens. But that's an expensive option in todays NOS tube market.
"The supercomputer is technologically impossible. It would take all of the water that flows over Niagara Falls to cool the heat generated by the number of vacuum tubes required." ~ Professor of Electrical Engineering, New York University
Old 5th October 2011, 04:02 AM   #9
Interesting, interesting...I'm learning a lot here. I'm not sure I quite understand the comment about C3 in the heater circuit. Can you explain the bit about "not bypass heater coupled AC hum?
As for increasing the value of the OTHER C3, the cathode bypass cap on the first tube, would that also increase gain and bass response?
I'll try the 6V battery test, that's such a simple and obvious strategy....
Thanks much!
Old 5th October 2011, 08:51 AM   #10
trobbins's Avatar
Hum voltage couples to the grid via stray capacitance - this mechanism is minimised by the humdinger pot, which effectively couples equal and opposite signals to the grid, such that they null.
Hum voltage also completes a current loop via the resistance between heater and cathode, the cathode bias circuit, and the heater/humdinger back to ground. Increasing the heater cathode resistance (by DC elevation) will lower the hum current flowing in this loop. Lowering the impedance of the cathode bias circuit (C3 in amp circuit) will lower the hum voltage developed across the cathode bias circuit. Lowering the impedance of the humdinger wiper to ground (C3 in power supply) bypasses any HT related hum voltage, which would otherwise add itself into the loop.
Hum voltage completes that same loop via capacitance between heater and cathode - and the same comments as before are valid, except that the heater-cathode capacitance doesn't change with DC elevation. It seems that capacitive impedance is much lower than conduction related resistance for the heater-cathode interface.
Yes cathode bypass C3 will change the bass response and increase gain (compared with not having a bypass capacitor), but one of the main advantages of capacitor bypassing the cathode resistance in the first preamp stage is actually the reduction in hum provided.
DC Blocking on Pre-Amp Puffin Chip Amps 8 22nd January 2009 08:08 PM
to convert a 12v dc car adapter to support 19 volts dc shadiedog87 Power Supplies 6 31st October 2007 07:27 PM
DC filament guitvinny Tubes / Valves 5 16th October 2006 02:15 PM
gates tube pre-amp info?? goingblind Tubes / Valves 0 6th January 2005 12:12 AM
DC in Pre-amp output Herman Chung Tubes / Valves 11 5th August 2004 10:14 PM
Page generated in 0.10656 seconds (80.63% PHP - 19.37% MySQL) with 11 queries
