how much C is too much C?
Old 4th October 2011, 04:54 PM   #1
mctavish is offline mctavish  Austria
Default how much C is too much C?
I was given a box full of some Rifa 5600uf @ 420v capacitors today. These are electrolytic caps and I was planning to use them in series for the power supply of a PP 6550 amp I am working on. Anyone know of any drawbacks to using this much capacitance in a tube amp? The PS will be CLC with SS diodes and around 120uf for the first C; 6hy @ 400ma. choke and the two monsters in series for around 2800uf @ 800v. B+ is around 580v. Do such large caps normally have higher ESR/ESL?
Old 4th October 2011, 05:29 PM   #2
DF96 is offline DF96  England
Your PSU will have a subsonic resonance at about 1.2Hz. Not necessarily a problem, although this could be in the range of syllabic rate for speech or music. The characteristic impedance will be about 46 ohms, so difficult to damp effectively. Smaller C would give a higher frequency, but better damped.
Old 4th October 2011, 06:27 PM   #3
tomchr is offline tomchr  Canada
tomchr's Avatar
You could change from CLC to CRC or flat out C and eliminate the resonance. With that amount of cap there should be plenty of ripple attenuation.
Beware that the caps will suck quite a bit of current at turn-on. Soft start (resistor in series with the primary of the transformer that's shorted with a relay after the supply is up) is definitely needed. Otherwise, you're almost guaranteed to pop fuses or blow the rectifier diodes.
~Tom
Modulus-686: 240W/8Ω @ <0.00025% THD. Modulus-86: 40W/8Ω @ 0.000054% THD. DG300B & Other Tube Circuits.
Neurochrome : : Audio - www.neurochrome.com - Engineering : : Done : : Right
Old 4th October 2011, 07:20 PM   #4
Thanks for the reply guys. Sounds like these should be fine then. Will implement current limiting upon turn-on. I have heard hey are quite nice caps as well, long life and supposedly low ESR/ESL (have not seen any numbers though). Will proceed as planned.
Old 4th October 2011, 09:53 PM   #5
ChrisA is offline ChrisA  United States
Resistance is good. It damps resonance. But maybe your choke has enough internal resistance and then you will need those voltage balancing resistors in parallel with the series caps. So it should work fine. Except the in-rush current at power on. You will blow a fuse as those caps will look like a short across the transformer. You might use a thermistor to reduce in-rush to something reasonable. Model the big caps as a short and add what it takes to keep the current limited to something less than infinity
Old 5th October 2011, 09:59 AM   #6
AndrewR is offline AndrewR  United Kingdom
I fould that large caps didn't work for me in a CLCRC circuit (excluding of course the first cap). The sound was very plain and boring, so I switched from the 330uF to 100uF and the music had better definition and timing. That might be due to the slower recharge/discharge times of the higher C values.
Anyway, give them a go, but please compare them with 100uF values as well.
Andrew
Andrew Randle
Old 5th October 2011, 10:53 AM   #7
Andrew
I had wondered about this having heard the difference before in a SE amp I built. I know that the PS in a SE amp has quite an impact on the sound however I was quite surprised to hear just how much. I was thinking that this application in a class AB push-pull amp with such a high amount of capacitance the caps would'nt be fully discharging, or is this incorrect? How much energy can a pair of 6550/KT88 really pull?
Old 5th October 2011, 11:15 AM   #8
Your caps should only fully discharge when you switch your amp off (assuming you have bleeder resistors). At all other times the last thing you want is full discharge, as this leads to serious levels of hum!
Old 5th October 2011, 11:25 AM   #9
So is Andrew referring to the dynamic charge-discharge when the amp is in operation? Do the smaller caps really do this faster, and a better question is will this actually have audible difference in a class AB P-P amp?
Old 5th October 2011, 12:19 PM   #10
I have no idea what he means. Perhaps he can explain it himself.
A smaller cap will certainly drop more voltage for a given withdrawal of charge - that comes simply from the definition of capacitance.
how much C is too much C?Hide this!Advertise here!
