how much C is too much C?
Old 5th October 2011, 12:54 PM   #11
AndrewR is offline AndrewR  United Kingdom
Originally Posted by mctavish View Post
So is Andrew referring to the dynamic charge-discharge when the amp is in operation? Do the smaller caps really do this faster, and a better question is will this actually have audible difference in a class AB P-P amp?
Yes the dynamic charge and discharge when in operation. If you use a dropper resistor in the PSU, or if the resistance of the choke is significant enough, then the RC time constant may become noticable.
However, thinking about it, if you are only using CLC (and not CLCRC) then you might be able to get away with higher values of C. It's when you get to using CRC, or similar, when cap size becomes very critical.
At the end of the day it is worth experimenting with values, hearing if there is a difference.
Andrew
Andrew Randle
Old 5th October 2011, 12:56 PM   #12
flatheadmurre is offline flatheadmurre  Sweden
A problem that can be is if you use caps with to high voltage rating they will go bad cause of never being fully charged.
20-30% over is a good rating (including startup peak).
Several smaller in parallel compared to one big for faster charge/discharge.
Old 5th October 2011, 01:22 PM   #13
TonyTecson is offline TonyTecson  Philippines
TonyTecson's Avatar
too much C? nah.....
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 5th October 2011, 02:01 PM   #14
They're in series not parallel :P
Andrew
Andrew Randle
Old 5th October 2011, 02:10 PM   #15
454Casull is offline 454Casull  Canada
When the mass of the caps is greater than the mass of the transformer(s).
Old 5th October 2011, 05:39 PM   #16
digits is offline digits
digits's Avatar
Too much C is simply when you spend more money on capacitors then what you could have spent on combinations of other parts to achieve the same ripple reduction for less money.
Old 5th October 2011, 06:22 PM   #17
mctavish is offline mctavish  Austria
The caps were the best price = free!! Now if only I can find a free pair of Lundahl OT'S I will dance a jig!!!
Old 5th October 2011, 11:03 PM   #18
TonyTecson's Avatar
Andrew
yup, this is a CRCRCRC filter bank.....
Old 5th October 2011, 11:05 PM   #19
TonyTecson's Avatar
same here, i did not pay for those caps, someone else did.....
Old 12th May 2012, 06:50 PM   #20
john65b is offline john65b  United States
john65b's Avatar
I am in the same boat - 2200uf 450 caps in a CLC circuit, and SS rectifier. First cap small at 4.7uf, then a 1.5H, then the 2200uf. It s a Quicksilver 8417 clone with KT88's.
I Speak Spanish to God, Italian to Women, French to Men, and German to My Horse. Charles V
how much C is too much C?Hide this!Advertise here!
Copyright ©1999-2017 diyAudio
