diyAudio Sponsor
Old 3rd October 2011, 09:54 PM   #1
aldovan is offline aldovan  Brazil
Default Driver for a 807 em triode mode...help !!!
Friends
To excite a 807 in single-ended triode mode is best to use a preamplifier tube with low plate current or large plate current to compensate the capacitance of the grid ?
Thanks,
Aldovan
Old 3rd October 2011, 09:56 PM   #2
aardvarkash10's Avatar
bigger is always better.
Yes, conservatism thrives on low intelligence and poor information. But the liberals in politics... continue to back off, yielding to the supremacy of the stupid. It's turkeys all the way down. - George Monbiot, guardian.co.uk, 6 Feb 2012
Old 3rd October 2011, 10:00 PM   #3
Default 807
Thanks.
Them I will put a medium power pentode in triode mode as driver.
A El84 is fine ?
Aldovan
Old 3rd October 2011, 11:06 PM   #4
absolutely fine - probably overkill.
Alternatively, PowerDrive it, ie use a MOSFET as a follower to drive the 807 grid.
Old 3rd October 2011, 11:08 PM   #5
Default Mosfet ?
Mosfet ? Blargh, Mosfet is trash !
Old 4th October 2011, 02:28 PM   #6
boywonder's Avatar
Default MOSFET follies and powerdrive
Aldovan: Here are a few links well worth the read........
http://www.geofex.com/Article_Folder...osfetfolly.htm
PowerDrive
Old 4th October 2011, 05:56 PM   #7
A have a stash of C3g usually works when other fails !!
Old 4th October 2011, 06:15 PM   #8
Triode connected 807 is not very difficult load since its mu is low, about 10.
Thus the Miller effect is not remarkable.
Any medium mu triode is suitable driver.
Looking for the triode mode of Z759 olaychang Tubes / Valves 0 22nd January 2010 01:29 AM
EM 1308 Driver ronzeman Multi-Way 1 8th August 2008 01:10 AM
E130L in Triode mode gorgon53 Tubes / Valves 38 5th July 2008 01:57 AM
Boosted Triode mode? Jeb-D. Tubes / Valves 2 21st August 2007 02:28 AM
Using a spdt switch to select between triode mode and pentode mode on a guitar amp. G Tubes / Valves 19 15th March 2006 09:15 AM
Page generated in 0.08684 seconds (76.29% PHP - 23.71% MySQL) with 10 queries
