diyAudio Sponsor
Old 3rd October 2011, 08:34 PM   #1
Default 6J6-based SSMH?
Anyone have any suggestions for a DIY headphone amp? I was looking into the SSMH, but I'd rather use something with a 12VDC power supply instead of a 48VDC one. I toyed around, and designed this:
I substituted 6J6's for the 19J6's called for in the original SSMH design, and replaced the 48VDC PSU with a 12VDC PSU. From there, I adjusted the resistors accordingly to keep the gate-source voltage at 5v. I am fairly new to DIY headphone amps, so I wanted a "pro" to take a look at it first. So, be nice?
The picture has a few typos; you need a ~1-2A @ 12VDC PSU, not a .5A one, and the "48V" should obliviously read "12V".
Old 3rd October 2011, 08:45 PM   #2
kevinkr's Avatar
Not sure how well the 6J6 is going to operate on 12V.. The main reason for the 48V supply was to have sufficient B+ for proper operation of the tubes.
www.kta-hifi.net
Old 3rd October 2011, 08:46 PM   #3
Frank Berry's Avatar
It's not going to work with a 12 volt supply.
If you must use 12 volts, why not use a transistor rather than a tube as your first stage amplifier?
Frank
Old 3rd October 2011, 09:03 PM   #4
DF96 is offline DF96  England
That design is a bit marginal even at 48V supply. The 6J6 is not brilliantly linear, although a headphone amp has quite small signals. The big problem at 12V supply will be distortion created in the source impedance (volume control, plus grid stopper) by grid current.
Old 3rd October 2011, 09:09 PM   #5
aardvarkash10's Avatar
12v B+ on a 6J6? Are you going to get enough (or any...) anode voltage movement?
Edit - Ooops beaten to it while checking the 6J6 spec...
Yes, conservatism thrives on low intelligence and poor information. But the liberals in politics... continue to back off, yielding to the supremacy of the stupid. It's turkeys all the way down. - George Monbiot, guardian.co.uk, 6 Feb 2012
Old 3rd October 2011, 09:16 PM   #6
12AU7 can work at low voltages, but it won't be very linear.
Old 3rd October 2011, 11:23 PM   #7
Gwah, I thought the "6" in "6J6" meant 6v. Anywho, not to be a bother, but would you have a suggestion on what to change out? Pardon my noobiness; I am willing, and wanting, to learn.
Old 3rd October 2011, 11:39 PM   #8
the first 6 refers the the heater voltage...
The 6J6 and 19J6 are essentially the same tube with different heater circuit characteristics.
Change nothing out in the signal circuit - you will need AT LEAST 48V B+, as discussed more would actually be better, although Pete may disagree.
Old 4th October 2011, 12:22 AM   #9
kevinkr's Avatar
Note that you will need to add resistance in series with the filaments as they form part of the output circuit, and you want to drop ~ half of the supply voltage across the FET and the other half across the resistor-filament combination for best linearity, and at a certain point excess voltage across the FET means excessive dissipation.. Go back the original circuit and calculate the series resistance based the filament current and as designed source voltage.. I think 51 ohms might be close enough **but check it** 5W resistor min...
Also Pete is a regular here, you might just send him a PM and see what changes he suggests to use the 6J6...
www.kta-hifi.net
Old 4th October 2011, 03:46 AM   #10
So like this? I was wondering exactly what goes where; I can't visualize it without a diagram.
Computer based 4 way x-over ? matsj PC Based 6 19th October 2011 07:25 AM
PC-based server versus network-based player hillbear PC Based 14 12th July 2011 12:13 AM
Chipamp-based Regulator? gootee Power Supplies 12 22nd January 2007 05:05 PM
Yet another Opamp based regulator banana Power Supplies 4 22nd January 2007 02:46 AM
Choosing a sub driver based on T/S... manxam Multi-Way 2 21st February 2004 10:16 AM
Page generated in 0.10276 seconds (78.87% PHP - 21.13% MySQL) with 10 queries
