Preamp input tube noise - diyAudio
Home Forums Rules Articles diyAudio Store Gallery Blogs Register Donations FAQ Calendar Search Today's Posts Mark Forums Read
Old 3rd October 2011, 03:11 PM   #1
Mielke is offline Mielke  Germany
Send a message via AIM to Mielke Send a message via MSN to Mielke Send a message via Yahoo to Mielke
Default Preamp input tube noise
Hello,
I wonder what different level pentode tube noise is to be expected from a pre with oldstyle octal input tubes like EF37, 6J7, WE 348A in comparison with newer noval tubes like EF804S or EF184. Are the newer tubes that quiter than the old ones and does that lead to a nearly noise free preamp or is the difference not that big?
Old tube have better tone qualities but I dont want them to be noisy in the quit passages of the LP record. So do I have to go with the new types?
Thanks, Mielke
Old 3rd October 2011, 08:56 PM   #2
ruffrecords's Avatar
As a rule, pentodes are noisier than triodes because of partition noise. For this reason, triodes are the most popular type of tube for use in an RIAA preamps.
Having said that, the noise sources in vacuum tubes is not generally well understood which means that many triode designs are noisier than they could be. This means it could be possible to design a pentode based RIAA preamp that is in fact quieter than many current triode designs.
To return to your original question, there are two major sources of noise at audio frequencies in vacuum tubes - shot noise and flicker noise. Of the two, flicker noise is generally the more serious and is mostly due to imperfections in the manufacture of the cathode. This means it can vary enormously between different samples of tubes of the same type but it also means that the quietest tubes will be obtained from the best manufacturers i.e. those who control their manufacturing processes the best. Since the art of vacuum tube making has arguably been mainly lost it is likely that samples of old types of tubes will be quieter than samples of their modern equivalents.
Cheers
Ian
Old 3rd October 2011, 09:11 PM   #3
DF96 is offline DF96  England
EF37A (not EF37) is supposed to be good. Miniature alternatives are EF86 or 6BR7. As Ian says, older ones (e.g. NOS) are likely to be better than recent manufacture.
His Master's Noise: A Thoroughly Modern Tube Phono Preamp SY diyAudio.com Articles 231 8th December 2015 11:21 PM
Noise on unconnected preamp input Gabriel.gobat Analog Line Level 12 31st March 2010 08:18 AM
Tube preamp hum and noise. marchel Analog Line Level 2 20th February 2010 04:23 PM
Tube Preamp Popping on Source Input Change (?) / 6DJ8 Preamp On Chip Amps MartyM Tubes / Valves 3 16th October 2008 05:52 AM
Suggestion on the input transformer for tube preamp bee696 Tubes / Valves 3 2nd August 2006 05:43 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
Copyright 1999-2016 diyAudio
