diyAudio Sponsor
Old 2nd October 2011, 04:42 PM   #1
Default What is the proper way to measure transformer inductance?
Hey Guys,
I'm working on some SPICE models for a tube amp design. I've had a lot of luck in finding specs and models for tubes. But, finding similar information for transformers is proving to be more difficult to find.
I've got some test subjects (UTC LS-55) and, I think I have all of the necessary test equipment:
  • KH 5920 function generator (nano to megahertz)
  • Instek digital o-scope (>20hz to gigahertz)
  • HP 4276A LCZ (100hz to 20kHz)
How would you go about measuring inductance? In particular, I'm getting a variety of readings from the primary, depending upon how I load the secondary (open, closed, resistor). What are some expected readings for either a 5k or 3k coil?
Thanks!
-Brian
Old 2nd October 2011, 05:41 PM   #2
Build a series resonance circuit with the transformer, a known capacitor and a adjustable resistor (10k to 100k). Feed the AC-voltage across this circuit.
If you have a guess about the inductance of the (primary) transformer, select the value of the capacitor so that the resonance frequency is relatively low (100 Hz to 500 Hz). Then observe the voltage across the transformer and the capacitor with your scope and by adjusting the frequency of your generator you can find the notch frequency.
Then you simply calculate the inductance.
You can get the notch more sharp if the series resistance is higher.
Old 2nd October 2011, 05:58 PM   #3
oshifis is offline oshifis  Hungary
You measure the main inductance with open secondary, and the stray inductance with shorted secondary. Measuring at low frequency (100 Hz or 120 Hz) is usually sufficient.
Old 2nd October 2011, 07:06 PM   #4
euro21 is offline euro21  Hungary
Fast method.
Old 2nd October 2011, 07:14 PM   #5
nigelwright7557's Avatar
Using the resonant method the formula is:
1
------------------ = f
2 pi sqrroot(LC)
So
L = 1
4 pi squared f squared C
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software.
Old 2nd October 2011, 07:19 PM   #6
Output transformer real measurement.
Old 2nd October 2011, 07:30 PM   #7
Of course for accurate measurement of a SE OPT you would need to load the primary with an appropriate DC current me thinks.
mike - www.keepingsundayspecial.org
Old 2nd October 2011, 07:54 PM   #8
trobbins's Avatar
The original Williamson articles provided a simple benchmarking technique for OT primary inductance comparison, given that inductance is quite dependant on excitation level.
I'm not sure if the transformer models include basic inductance versus excitation variation modelling.
Old 2nd October 2011, 08:10 PM   #9
richwalters's Avatar
What's the reason for wanting to measure o/p tranny inductance it ? On E&I types, inductance is never specified as the miniscule airgap between the laminations when screwed up can wildly alter the figures. A toroid with continuous strip is far more predictable.
richy
Old 2nd October 2011, 10:55 PM   #10
This looks promising...
How to measure leakage inductance percy Power Supplies 17 29th August 2008 09:57 PM
How to measure inductance in the x-over. marchel Multi-Way 3 12th December 2007 11:23 AM
Who might be able to measure inductance? fazman Multi-Way 8 21st August 2006 12:26 PM
measure inductance henryp Parts 2 5th July 2006 10:44 PM
How to measure inductance? Jimmy154 Multi-Way 41 20th July 2003 03:37 AM
Page generated in 0.11413 seconds (79.49% PHP - 20.51% MySQL) with 11 queries
