diyAudio Sponsor
Old 1st October 2011, 12:02 AM   #1
mr2racer's Avatar
Default Tube Phono Pre-Amplifiers
Does anyone have design for a tube phono pre-preamp?
Old 1st October 2011, 12:11 AM   #2
SY's Avatar
First questions to consider before choosing (or designing):
1. Cartridge output?
2. Best loading for cartridge?
3. Desired gain?
4. Load to be driven? (usually 47k in parallel with some capacitance)
5. Acceptable degree of complication/expense?
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 1st October 2011, 12:15 AM   #3
6L6 is offline 6L6  United States
6L6's Avatar
Yes. However, it would be helpful to see your answers to SY's questions.
Old 1st October 2011, 07:49 AM   #4
Here is one quite basic circuit which gives good results with MM cartridges. Gain is some 46 dB.
Kuva 19470 - Kuva.termiitti.com
Old 1st October 2011, 11:00 AM   #5
SY's Avatar
The OP was looking for a pre-preamp, i.e., a flat gain amp to step up an MC to MM levels.
Old 1st October 2011, 11:21 AM   #6
If (as SY thinks) you are looking for something to use instead of a SUT between a LOMC and a "routine" phono section, you are asking for trouble. Tubes are simply too noisy for use at these μV. level signals.
OTOH, if you want something to put between a MM level cart. and the line section, there are any number of satisfactory tube based designs available.
Please clarify your intentions and needs.
Eli D.
Old 1st October 2011, 12:00 PM   #7
How can you make such assumption ? I could not.
To me phono pre amplifier is such that contains RIAA correction and adequate gain.
mr2racer, could you clarify.
Old 1st October 2011, 12:07 PM   #8
SY's Avatar
He said pre-preamp, not preamp. Yes, clarification is in order.
Old 1st October 2011, 12:12 PM   #9
Yes indeed, pre-preamp.
Old 2nd October 2011, 06:21 AM   #10
If he is going to use a MC then how about a simple step up transformer using 2) 4722 Altec transformers to provide the necessay gain to marry the signal to a standard phono preamp? I believe Altec 15095 or 15095A's will also work also.
Http://members.myactv.net/~je2a3/mic-mcstep-up.htm
What tube for QUIET phono pre?? Freecrowder Tubes / Valves 8 27th August 2010 12:17 PM
Tube phono pre-amp needed. Runco990 Tubes / Valves 28 23rd March 2007 03:20 AM
Question about Thorsten's Tube Phono Pre BHD Tubes / Valves 0 1st February 2007 01:12 AM
Tube Phono Pre of RJM ebijma Tubes / Valves 5 30th September 2005 12:04 PM
Page generated in 0.09279 seconds (85.38% PHP - 14.62% MySQL) with 11 queries
