Class A tube amplifier Kit - Page 4 - diyAudio
Old 30th September 2011, 03:05 PM   #31
boywonder's Avatar
Originally Posted by cjkpkg View Post
Check out TMAMPS for some ideas. One that stands out would be the JELabs EL34 SE amp. You will have to do it P2P but there are many examples at this site for layout and components. Uses common driver tubes too 6SL7 and a pretty simple build. JELABS EL34 Schematic
Edcor iron and Hammond chokes.
I also have a Tubelab SimpleSE which is an awesome amp and would highly recommend it if you wanted to go PCB route.
A friend wanted a budget SE amp, and we had some old iron, so we threw together the JELabs 6SL7/EL34 design off of the Angela Electronics site. It may have been our build, but it wasn't very impressive, and the square waves were anything but. We have since procured all the parts required to rebuild it into a P-2-P Tubelab Simple Single Ended.
Old 30th September 2011, 03:43 PM   #32
cjkpkg is offline cjkpkg  United States
Yes, I still go back to my SimepeSE, as a matter of fact I am listening to it right now...It is a really sweet amp!
Running Edcor CXSE's (the monster ones)
EHKT90's @ 89mA each
465V B+
Mullard 12at7 variant
Jantzen silver Z coupling caps
I must say that this is a most tweakable amp and I learned a heck of a lot building and tweaking it.
Old 30th September 2011, 11:26 PM   #33
You should really check out the amp that is my signature. Very good reviews and the master kit includes everything except tools and time.
Class A amplifier kit Altecboy Swap Meet 0 29th March 2010 05:18 PM
Tube Amplifier Kit? theblackknight Tubes / Valves 11 14th February 2008 07:55 PM
DIY AMPLIFIER KIT -- > class d? need info!! JinMTVT Solid State 6 30th April 2006 06:00 PM
PCL82 SE Tube Amplifier Kit savakovacevic Tubes / Valves 4 28th January 2006 09:41 AM
Copyright 1999-2017 diyAudio
