Class A tube amplifier Kit - Page 3 - diyAudio
Old 29th September 2011, 07:42 PM   #21
lduarte1973's Avatar
i was looking for a complete kit or an assembled amp
Old 29th September 2011, 08:04 PM   #22
data is offline data  Australia
Ooops!
Deleted, the postage is a bit high
Old 29th September 2011, 08:18 PM   #23
john dozier's Avatar
The ST35 is your best bet. I tri-amped a system and put 50watt/channel on the top and it worked great becaused the amp was primarily in class A. You would find the same with the ST35-also easy to hot rod with better caps, etc. Try Solen Teflon and foil for coupling. Regards
Evil looms. Cowboy up. Kill it. Get Paid.
Old 29th September 2011, 08:26 PM   #24
Made a mistake
Resume normal program
Old 29th September 2011, 08:38 PM   #25
There are several versions of the ST35 kit from at least two manufacturers. Both of which have good reputations. Tubes are also relatively inexpensive not the case with 2a3 or 300b tubes. Regards
Old 29th September 2011, 08:54 PM   #26
Since you mentioned the 2a3 how about some mono blocks
Paramour
OK, I'm done
Old 29th September 2011, 09:41 PM   #27
Even with the gain supplied by two tweeters you are still looking at 93db. I suspect the paramour may be a bit underpowered for this application. Seems to be a nice unit though if you have 99+db drivers.
Old 29th September 2011, 09:50 PM   #28
That kit is no longer available any more anyway
My aversion to the Dynaco is a personal one, I don't like UL
But it is not about me, and is what ever the OP likes, so It's good that he has been given the option of the Dynaco amp, be nice if he had a few different options to look at, is all.
Old 29th September 2011, 11:00 PM   #29
kevinh is offline kevinh  United States
Here is the current Bottlehead SE kit for $750 USD.
Stereomour Stereo Single Ended 2A3/45 Integrated Amplifier Kit
Also very good preamps available. The kits are complete and have good quality transformers.
Old 30th September 2011, 02:06 PM   #30
cjkpkg is offline cjkpkg  United States
Check out TMAMPS for some ideas. One that stands out would be the JELabs EL34 SE amp. You will have to do it P2P but there are many examples at this site for layout and components. Uses common driver tubes too 6SL7 and a pretty simple build. JELABS EL34 Schematic
Edcor iron and Hammond chokes.
I also have a Tubelab SimpleSE which is an awesome amp and would highly recommend it if you wanted to go PCB route.
Class A amplifier kit Altecboy Swap Meet 0 29th March 2010 06:18 PM
Tube Amplifier Kit? theblackknight Tubes / Valves 11 14th February 2008 08:55 PM
DIY AMPLIFIER KIT -- > class d? need info!! JinMTVT Solid State 6 30th April 2006 07:00 PM
PCL82 SE Tube Amplifier Kit savakovacevic Tubes / Valves 4 28th January 2006 10:41 AM
Copyright 1999-2017 diyAudio
