#11 | |
In short you have "over specified" the problem. That means you have so many conditions that not all can be true at the same time. The tubelab simple SE could work for you. But you asked for a complete kit. If that is what you need look here: DIYTube Dynaco ST35 Tube DIY Amp Kit Great for iPod This is about $500, has all the power you asked for but is not single ended. But on the other hand the Dynaco ST35 is a very good and well respected amp with a long history and this kit ships with very good transformers. I'm building something very much like the ST35 right now. but using Hammond transformers salvaged from a broken church organ. These salvaged transformers were designed to drive "tweeters", above 600Hz at 15W power but will handle bass fine if I limit the power. This amp will drive some 96dB speakers in an upstairs bedroom where not much volume is required. I could built this with new parts for 1/2 your budget |
#12 | |
#13 |
Was in my first post. He only has the one partial kit, it includes all the parts other than "Does not include valves, timber chassis plinth, feet, volume knob, and mains lead." All his other amps are as completed builds.
Here again... sb343971 - Kit Amplifier Last edited by data; 29th September 2011 at 04:38 PM. |
#14 | |
#15 | |
#16 | |
i´ll be crossing the tweeters > 5khz , so maybe i dont need much power indeed |
#17 |
i can double my budget cause i´d realy like to get a single ended amp , thought i could get away cheapier...
#18 |
Be careful with some of the Chinese amps, as often they state things like being "Class A" when they are not really "Class A". Whatever you are looking at, research it well.
#19 |
#20 |
there seem to be plenty of el84 SE schematics around
| Class A amplifier kit | Altecboy | Swap Meet | 0 | 29th March 2010 05:18 PM |
| Tube Amplifier Kit? | theblackknight | Tubes / Valves | 11 | 14th February 2008 07:55 PM |
| DIY AMPLIFIER KIT -- > class d? need info!! | JinMTVT | Solid State | 6 | 30th April 2006 06:00 PM |
| PCL82 SE Tube Amplifier Kit | savakovacevic | Tubes / Valves | 4 | 28th January 2006 09:41 AM |
