diyAudio Sponsor
Old 27th September 2011, 05:50 PM   #1
Default Best design for Lundahl LL1679/PP
Hi
I am looking for good design to utilize spare Lundahl opt's LL1679/PP , I can choose between secondaries impedance 2k6 - 4k5 - 9k7.
Thank for any advice
PS.: everything apart of EL34PP which I have already built , preferably 300B
Slav
Old 27th September 2011, 06:15 PM   #2
rmyauck is offline rmyauck  Canada
Kevin Kennedy a member on this site has this amp which should work with your OPT's.
300B Stereo Amplifier
A 30W 300B PP Monoblock You Can Build by Kevin Kennedy in Engineering
Old 27th September 2011, 07:37 PM   #3
Kevin Kennedy monoblocks looks good , but I would preffer integrated amp.(already have chassis), any other options?
Slav
Old 28th September 2011, 01:07 AM   #4
Possibly use one PS trans of double the amperage rating or more for all windings, then split off each from each lead to each amp on the same chassis. Should get great separation that way, and still a great solid PS.
Old 28th September 2011, 10:48 AM   #5
soulmerchant's Avatar
Nice transformers! To me the only question is how many watts you want and how much you want to spend..
Instead of expensive 300B, how about 6AV5's in triode mode driven by 6BL7's using 12sn7 phase splitter?
Of course my preference would be to use the above tubes in single ended design , but those are really such nice PP OPT's... maybe you want to sell them???
You should think about the power supply as well. I like to use use television damper diodes, chokes and motor run capacitors.
Old 28th September 2011, 12:24 PM   #6
Hi soulmerchant
Power is not an issue , everything between 20-50 Watts.
300B was my first thought as this is such a common tube and I have read lot of good reviews.
Sorry I won't be selling those , 6AV5 would be interesting, do you have any particular design using those tubes on hand?
Best Regards
Slav
Old 28th September 2011, 08:24 PM   #7
Originally Posted by slav View Post
Hi soulmerchant
Best Regards
Slav
You could try any design for 6b4 or 6a3 or ... 2a3 that is highly rated. But use 6AV5 in triode. You won't get 20 watts though - Maybe 8 watts depending on the output transformer you are using. But oh those are very NICE sounding watts.
Old 2nd October 2011, 09:08 AM   #8
Default Decision has been made
Hi
Finally I decided, it's going to be Andrea Ciuffoli Parallel PP based around EL34 (yet again).
Here is the link:
PP2010 - Hi-End Push Pull Amplifier
I don't like His approach to PSU , what would be the best for Push/Pull amplifier?
I am thinking CLC filter to B+ , then RC to driver and phase splitter.
But I am not entirely sure what values of components shall I use .Too big value of input capacitor doesn't do any good to power transformer - huge charging spikes .Can you point me to some good Push/Pull PSU literature.
Old 5th November 2011, 12:52 PM   #9
Default It's so hard to make right decision
Hi
I have ordered chassis , PCB for the project , pair of 8H-350mA chokes, main transformer 2x340V plus 100V and heaters supply , and started having doubts if I have made right decision. As I have already tried El34 in PP , I wonder if it makes any sense to built another amp based around same tube , so I read some stuff about other PP options and KT88 make me to think to change object of my interest .More I think more confused I become .Please help me , what would you choose :
or something based on KT88, as simple as that:
What I am listening to? Pretty much everything : classical ,jazz, pop,rock, metal
which tube is more universal?
Old 13th November 2011, 09:00 AM   #10
Any comments on HK10 schematic ?
PSU looks horrible , but what about amplifier .paralleled 12U7 is my main concern.
FS: Lundahl Tube Amp PP Transformers andyjevans Swap Meet 6 10th January 2011 11:34 AM
FS: Lundahl and other Tube Amp PP Transformers andyjevans Swap Meet 10 15th September 2010 05:02 PM
Wanted:Lundahl LL1679 max29 Swap Meet 0 16th February 2009 10:27 AM
845 PP and Lundahl 1620 audiobot Tubes / Valves 187 22nd June 2004 11:48 PM
Page generated in 0.10530 seconds (79.05% PHP - 20.95% MySQL) with 11 queries
