diyAudio Sponsor
Old 27th September 2011, 04:46 PM   #1
mr2racer's Avatar
Default 12U7 LTP vs. 6922 cascode
Hey All,
I hve a pair of Dnaco Mark VI monoblocks that I converted to a LTP 12Au7 front end and 6922AU7 driver section with KT88 outputs. After a few months of listening I'm not happy with the amps. They just sound a bit harsh at volume. (Ithink this may be caused by too much voltage on the 12au7"s. I recently built a pair of Mark III clones using a cascODE 6922 front end. Would the cascode be preferable?
Kevin
Old 27th September 2011, 05:14 PM   #2
DF96 is offline DF96  England
The LTP and cascode are such different circuits that it is a bit difficult to conceive that they might be alternatives for a given job. LTP is used when you need a balanced input and/or a balanced output, and are happy to lose a little gain and add a little noise but greatly reduce even-order distortion. Cascode is used when you need high gain and low input capacitance for low level signals so distortion is not a problem. Oh, and they have very different PSRR.
Old 27th September 2011, 08:14 PM   #3
ppl is offline ppl  United States
ppl's Avatar
Why not Both an LTP built with (2) Identical cascodes
Old 27th September 2011, 08:59 PM   #4
mr2racer's Avatar
Sorry about the really poor typing. I was trying to to this while at work before the boss noticed what I was doing. I don't have balanced inputs or outputs and I don't need more gain. Getting a Mark VI apart is a bitch. And If I was going that far I thought I might use the cascode since I have four 6922's. But the original design used the LTP so I'll try to make that work.
But I still have these 6922's. Could you use a pair of cascode 6922's as a line amp?
Kevin
Old 27th September 2011, 11:13 PM   #5
dgta is offline dgta  United States
Kevin
If the first statement is true, both the 2nd and 3d are false.
Mark Vi is pentode VA > Concertina splitter > PPP finals.
Free Dynaco tube schematics
Old 28th September 2011, 12:04 AM   #6
You may want to look here:
CURCIO AUDIO Dynaco Mark-4 Amplifier Upgrade
Curcio Audio Engineering (CAE) offer a 6922/6DJ8/6N1P Differential Cascode front end upgrade board for the MKIV. It has an integrated HV regulator on the board to address the fact that cascodes have low power supply rejection.
I've used these boards, they work well. Only problem I ever had was a "running water"/"surf" sort of sound from one card which turned out to be a microphonic tube and not a circuit fault at all.
Ian
Old 28th September 2011, 05:32 AM   #7
Ian, that one sure doesn't look like a differential cascode to me. And no regulator:
http://www.dynaco-doctor.com/MK4-DVR-DOC.pdf
Do they make another board?
Old 28th September 2011, 06:06 AM   #8
... I was trying to to this while at work before the boss noticed what I was doing...Kevin
LOL. Been there done that.
Old 28th September 2011, 06:19 AM   #9
OOPS - is my face red.
I was thinking of this one - the MK3 "Premium Mod", their PCB-1A board or ASM-1A Kit.
http://www.dynaco-doctor.com/mk3des_3.htm
That is the one I have used. I used it with 6SN7 cathode followers after it to drive parallel push pull KT88.
It was only a prototype amp using Hammond 1650T Output Tranny and I only ever built the one channel but I liked it.
It sticks in my mind because I also tried that prototype monoblock with PAT4006 Plitron Torroidal Output Tranny and decided I liked the half the price Hammond better. It was also 5 or 6 years ago before I went off on the Baby Huey track.
The one I linked is cascode into a triode diffamp and seems to be the same circuit as MK3 "standard" upgrade board.
Sorry about that.
Ian
Old 28th September 2011, 06:19 AM   #10
revintage's Avatar
dgata,
Thatīs not the one.
The diff cascode was first presented in GA. I have also tried them but built them from GA instead of buying cards. I had them in a pair of MkIV mnay years ago. The late Bo Hansson of Opus3 also produced a amp, Candela, with the same front end and 6L6, that was no hit for me. Ian and have different opionions as I didnīt like this driver at all.
mr2racer,
No success until I combined the front-end with E182CC CF. Then it was OK but not more. AS pointed out by Ian this was for a pair of EL34. Driving two pairs of 6550/KT88 isnīt the same thing.
If you have built something with 12AU7 I can understand it sounds unsatisfactory.
Brgds
Lars
829B as LTP? DrewP Tubes / Valves 10 17th June 2009 07:00 PM
LTP question m6tt Tubes / Valves 3 16th February 2009 11:14 PM
ecc40 LTP Jaap Tubes / Valves 17 23rd November 2008 12:22 PM
why does 12u7 need certain amount of gain to stop hum 120??? prorms Tubes / Valves 1 16th October 2008 04:33 AM
LTP using SSM2210 sss Solid State 0 12th December 2003 07:05 PM
Page generated in 0.10558 seconds (79.84% PHP - 20.16% MySQL) with 11 queries
Copyright Đ1999-2012 diyAudio
