diyAudio Sponsor
Old 27th September 2011, 05:05 AM   #1
Bengali is offline Bengali  United States
Default 12ax7 12au7 preamp
please refer to schematic for this pcb:
tube 12AX7 12AU7 preamp pre-amplifer golden plated pcb | eBay
What kind of gain does this produce? Should the Pot be 100K?
Any ideas on the values to better optimize? Seems like simple build with
the pcb.
Thanks for any info on it
Old 27th September 2011, 09:00 AM   #2
revintage's Avatar
20dB. Donīt build it!
Brgds
Lars
Old 27th September 2011, 09:51 AM   #3
Rodeodave's Avatar
What's wrong with it?
Gravity - Making the G since 13.7 billion B.C.
Old 27th September 2011, 10:27 AM   #4
DF96 is offline DF96  England
Really strange design! It starts with a high gain high impedance valve (12AX7) but then throws away the gain by using strong degeneration and a relatively low anode resistor. Having done this, the sensible thing to do would be to follow with a CF but this uses another similar stage. The resultant high gain and high output impedance then has to be tamed by using feedback. Not enough feedback to really suppress higher-order products, though.
It looks like a valve circuit designed by someone brought up on BJTs.
Old 27th September 2011, 10:50 AM   #5
revintage's Avatar
Brgds
Lars
Old 27th September 2011, 10:56 AM   #6
Merlinb is offline Merlinb  United Kingdom
The PCB and basic topology is usable though. There's nothing to stop the OP using an ECC82 or ECC81 as an alternative, and either eliminating or changing the cathode degeneration and feedback loop. You could even ignore the second stage and arrange the first stage as a cathode follower for a unity gain buffer. Would make an neat and simple platform for a beginner to play with.
Old 27th September 2011, 12:30 PM   #7
cjkpkg is offline cjkpkg  United States
spend some time at TUBECAD and study the different aikido, cathode follower, and other topologies discussed there.
I learned a heck of a lot by doing so and ended up ordering a simple 5687 aikido preamp kit. I am also a repeat customer because his products are proven, very good quality, and support is wide in this forum.
Not saying the preamp link you posted is bad - BUT if you are just starting out I would hate to see frustration come out of a build if you are.
The manuals have all kinds of good information too since his circuits allow for tube rolling with minor resistor value tweaks.
People have very good luck with using tubes like the 6dj8, 6h30, 6cg7, 6n1p to name a few. A gain that seems to generally work well for hi-fi ranges between 5 - 15 at most.
For a typical preamp a pot value of 50K or 100K should work just fine. I typically use Alps 100K stereo pots available at mouser. A stepped attenuator in that value range would be nice as well.
Old 27th September 2011, 02:23 PM   #8
Gobble is offline Gobble  India
I am looking for a preamp for my MyRef Gainclone and see-sawing between the Grounded Grid and Aikido.
I heard a borrowed GG in my setup and funnily (and wonderfully) it made everything in between the CD and speakers disappear. Then I've had little luck in finding good 12AU7s amongst many NOS I tried so want to move away from 12AU7s. Also the Aikido promises to be cheaper.
How would you rate the Aikido on delivering excitement and ability to lift veils from the music?
---G0bble
Old 27th September 2011, 02:56 PM   #9
yeah, I confess, I bought it.
I don't have intimate knowledge of all the topologies,yet.
I've built several aikido's though.
I figure some one here would have a great circuit to replace
the original one if it's really that bad. The board is nice enough to
make mods.
Old 27th September 2011, 02:57 PM   #10
It is the only preamp I have built where I do not feel the need for any kind of equalization. I have built some op-amp pre's and a Pass JfetBOZ. In my opinion what is recorded at the source is what comes over the speakers.
The aikido sounds just as good with a 6W SE amp as well as a MOSFET amp like a Pass F5. The beauty is being able to swap input tubes to fine tune the gain. I typically roll between 6CG7's and 6DJ8's depending on the power amp.
Preamp tube SRPP 12AU7 VS preamp tube Aikido 12AU7 = all use rec 6X5GT spiritm2r Tubes / Valves 1 6th March 2011 02:53 PM
Cascode Tube Mic Preamp: 12AX7/12AU7 Schematic 88man Tubes / Valves 11 10th December 2009 03:23 PM
12AU7/12AT7/12AX7 preamp schmatic needed Sal Brisindi Tubes / Valves 6 17th October 2009 03:48 AM
12AX7, 12AU7 Substitution Valvomaniac Tubes / Valves 13 22nd March 2007 08:44 AM
12AU7 or 12AT7 instead of 12AX7 ? Gubby Tubes / Valves 5 25th June 2004 11:31 PM
Page generated in 0.10815 seconds (80.07% PHP - 19.93% MySQL) with 11 queries
Copyright Đ1999-2012 diyAudio
