diyAudio Sponsor
Old 21st September 2003, 10:37 PM   #21
Sjef is offline Sjef  Netherlands
Originally posted by fdegrove
Hi Sjef,
Seems you're posting in stereo....errrr, well, almost.
Just be glad I'm not a 5.1 dolby surround guy
Old 21st September 2003, 10:44 PM   #22
diyAudio Senior Member
fdegrove's Avatar
We're sure keeping you busy tonight, aren't we?
Frank
Old 27th September 2003, 05:20 PM   #23
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
Very nice stuff.
BTW, the 6P3P is the Chinese equivalent of the 6L6 if I'm not mistaken.
Erm... Russian... And 6P3C[-E] is the 6L6GB (not GC, but it won't melt in a GC amp). <Colt correct my Cyrllic plz >
Tim
P.S. Frank and EC8010, keep discussion on the discussion thread
See my Electronics webpage -- the home of Vacuum Tube Drag Racing.
The key to being a successful Audiophile: "I reject your reality and substitute my own!"
Old 27th September 2003, 05:31 PM   #24
fdegrove's Avatar
To the best of my knowledge the Chinese manufacturers used to ( or perhaps still do) the same coding system as the Russian do.
I don't know where you get the idea but EC8010 isn't even involded in this thread.
Cheers and cheer up,
Frank
Old 27th September 2003, 06:30 PM   #25
wd40 is offline wd40  China
wd40's Avatar
For once the greats quantity adoptd the former Soviet Union technique in Chinese early phase , therefore the vacuum tube also adopts such naming means .
My english is very poor.
Old 28th September 2003, 04:44 PM   #26
wd40's Avatar
audioman:"this my new amplifier push pull 845"
Great !Transformer Phase Splitters ?
Old 2nd October 2003, 03:54 AM   #27
PassFan is offline PassFan  United States
Default P-P 6L6
Okay, here is my new amp which is a push pull 6L6 Ultralinear design by Hafler. It uses a 6SL7 input with a 6SN7 driver. I am sure the more astute of you will notice the mismatched output tubes which is the result of a dropped tube (first one I ever had break). So now I am waiting on another matched set. For the age of the design (1961) it sounds great so far. It ain't single ended but it ain't solid state either.
Some of you may recognize it from my Running Tube Amp Construction thread.
Old 3rd October 2003, 10:47 AM   #28
Default My 300BXLS amp
Posted a picture of my amp. I uses a 300BXLS from KR. The output tranny is a amorphous core and silver secundairy windings.
The driver is a 27 in a mu-stage configuration.
My preamp uses an old posttube the Ba, also switching it for the Aa.
regards,
Jan
Old 7th October 2003, 06:47 PM   #29
Tim said:
I would presume it has little to do with linearity about Vg=0V, and everything to do with having a cap-coupled driving stage. Often used in RF for class C stages: grid current has to go somewhere in this circuit, and it flows through the grid leak, back into the cathode, developing a negative voltage across the grid leak, biasing the grid negative. As a result, bias is always equal to the peak voltage of the input signal.
Wouldn't the grid be more positive than the cathode assuming grid current flows through cathode via grid resistor? How do you develop a negative voltage across the grid leak?
Just trying to understand,
Rick
Old 7th October 2003, 07:15 PM   #30
fdegrove's Avatar
Shunt gridleak biasing principles are explained here:
It's not very common in recent tube preamps but it used to be in Western-European circuits by Telefunken, Studer et all in the Sixties....
Frank
OT - How many of you here are also photo buffs? (nt) KT Everything Else 0 14th October 2004 03:27 AM
My DAC Photo MCLL Digital Source 4 27th April 2003 10:47 AM
Page generated in 0.13083 seconds (73.32% PHP - 26.68% MySQL) with 11 queries
