| diyAudio Sponsor | ||
I am designing an amplifier using this 6L6 datasheet.
6L6-GC pdf, 6L6-GC description, 6L6-GC datasheets, 6L6-GC view ::: ALLDATASHEET ::: The amplifier will be running AB1. The column I am using on the datasheet is for 26.5 Watts. I am trying to use the tube curves to determine the gain of this push pull stage, but none of the curves are based on the 270 V screen voltage. One set of tube curves is based on 250 V of screen voltage, but the operating point doesn't line up due to the screen voltage. Can someone help me figure out the gain of this stage please? It is the missing link for my amp. Nobody replied to my last post earlier. I'd really appreciate someone replying, or is this question too easy to be answered and I'm simply just an idiot? |
#2 |
Tinkerer
I ll reply!
250 to 270 = almost no difference. Just a little more G2 current and a little more power. Proceed as you planned! |
#3 |
Thank you man. I could not get anyone to answer my question. If wouldn't mind answering one more, for my G2 resistor, would I be using the zero signal screen current and the voltage drop across the G2 resistor to find its value?
#4 |
Did we really need this thread three times?
6L6 AB1 question. Please help. 6L6 AB1 question. Please help. |
#5 | |
P= V^2 / R V= sqrt(P*R) V= sqrt(26.5 * 6600)= 418.21Vrms Vp-p= sqrt(8) * Vrms Vp-p= sqrt(8) * 418.21= 1182.88Vp-p Across the whole primary Vi= 45Vp-p Av= 1182.88 / 45= 26.29 On primary side, across 6K6 If using Rl= 8.0R: Zn= 6600 / 8= 825 : 1 (Pri : Sec) Vn= sqrt(Zn)= sqrt(825)= 28.72 : 1 (Pri : Sec) Av`= 26.29 / 28.72= 0.92 (Across Rl= 8R) |
#6 |
Section 6 of the radiotron designers handbook fourth edition explains how to calculate the unpublished characteristics. You can download from pmillet technical books online.
Alfredo |
#7 | |
Tinkerer
#8 |
patience is a virtue. 24 hours is not an unreasonable amount of time to wait when people (often highly qualified and busy and incredibly knowledgeable people, far better experienced than me) are giving a reply...
Impatience also looks whiney. Maybe not in this case, but in others I've noticed
Yes, conservatism thrives on low intelligence and poor information. But the liberals in politics... continue to back off, yielding to the supremacy of the stupid. It's turkeys all the way down. - George Monbiot, guardian.co.uk, 6 Feb 2012 |
#9 |
Did this spreadsheet a few yeras ago http://www.revintage.se/PPABAMP.xls . For only outputstage gain set PI gain to 1. It is based on loadmatch3-pp-triodes
You will arrive at in the ballpark of Miles figures though. To simplify his calculations you can easily make a spreadsheet for that too.
Brgds Lars Last edited by revintage; 27th September 2011 at 08:17 AM. |
#10 |
www.kta-hifi.net |
| Reply emails | kilowattski | Forum Problems | 4 | 27th October 2004 02:41 AM |
| Quick reply if possible, please | mazeroth | Multi-Way | 14 | 28th September 2004 06:42 AM |
| reply | Bull | Multi-Way | 10 | 8th April 2003 06:36 PM |
| Page generated in 0.12144 seconds (83.42% PHP - 16.58% MySQL) with 10 queries |
