diyAudio Sponsor
Old 26th September 2011, 02:25 PM   #1
Default tube line preamplifier circuit
hello,
I am searching for a tube line preamplifier schematics. Does anybody knows a very good sounding designs? I do not have any tubes so i have no limitation on that.
thank you
Old 26th September 2011, 02:32 PM   #2
SY's Avatar
What sort of preamp are you looking for? Gain? Levels? Impedances?
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 26th September 2011, 02:47 PM   #3
scafas is offline scafas  Italy
Default pre tube
I built this preamp, and I assure you that sounds really good and it 'easy to build.
with some modifications it can operate at low voltage
http://www.pcb-audio.com/circuiti-st...hema-gomes.jpg
w w w . p c b - a u d i o . c o m
Old 26th September 2011, 03:19 PM   #4
hi,
it don't need to be low voltage. I had made a Piaa tube preamp before.Also i can make any transformar needed. I need a line tube preamplifier with low gain, 2-3 would be fine. It will be connected to my diy mosfet amplifier and speakers.
my new diy speakers project
Old 26th September 2011, 04:13 PM   #5
kevinkr's Avatar
Depending on budget you might even want to consider something like a 26 dht transformer coupled line stage.. Low gain (4dB or so) low output impedance, and no concern about leaky coupling caps or long LF time constants putting DC into your solid state amplifier.
The down side is complexity and cost. I'm incidentally running such a pre-amplifier in my system.. Check out the 26 pre-amplifier thread in this forum..
Other good possibilities would be Salas 6V6 based line stage, and SY's Heretical..
www.kta-hifi.net
Old 26th September 2011, 07:44 PM   #6
With some friends we have built a tube based I/V converter for DACs wich does not need a preamp.
greg
Old 27th September 2011, 01:53 PM   #7
what do you think about this design?
my 6922 / E88CC preamp
Old 27th September 2011, 03:39 PM   #8
DF96 is offline DF96  England
Far too much gain? A voltage gain of around 20 would only be needed with a very low output source or a very high input power amp.
Old 28th September 2011, 09:33 AM   #9
Tinkerer
This schematic is of the "Valves make nice distortion" type. Avoid it.
Old 28th September 2011, 10:44 AM   #10
I'm really confused here. Too much gain? Do you not have a volume control in which to adjust the level? Can you not make the necessary adjustments to achieve the volume level that is to your liking? Made a 12B4 line stage and the volume control setting was usually around 1:00 for the level that I wanted. Another line stage with more gain would result in a volume control setting of say 10:00 for the same level. Please do tell me what I am missing here. My distortion analyzer results were practically the same despite volume control setting. Are you trying to say that a line stage with lower gain will result in lower distortion? If so my test results have not come up with the same conclusion.
Line stage preamplifier anders.a Tubes / Valves 16 26th August 2010 10:47 AM
Line and Headphone Preamplifier/Amplifier Jean-Paul_2 Headphone Systems 4 11th June 2009 07:22 PM
anyone with a low noise preamplifier circuit for guitar? winner Instruments and Amps 3 14th January 2009 06:51 AM
X1 preamplifier circuit advice AD Pass Labs 7 18th April 2008 05:08 PM
suggest preamplifier circuit jaya000 Solid State 10 11th April 2007 06:55 PM
Page generated in 0.10252 seconds (77.44% PHP - 22.56% MySQL) with 11 queries
