| diyAudio Sponsor | ||
#11 | |
But what should the advantage be to use it as driver? In our amps we call it TULP(Triode-UL-Pentode) as it is continously variable.
Brgds Lars |
#12 | |
Butler, F. Transistor Wide-band Cascade Amplifiers. Wireless World, March 1965. p125. "Fig. 4 is another circuit which at first sight looks promising but which, on closer investigation, turns out to be rather disappointing... Moreover the reduced output impedance is achieved at the expense of disproportionate reduction of gain." |
#13 | |
#14 |
#15 | |
#16 |
"however that Topology may Be covered by U.S. patent number 4,647,872 ?"
1987 patent, 20 years coverage till 2007, so expired anyway.
Ohms Law V = I R |
#17 | |
#18 |
It looks like that the Tube Cad Tetra Sans also uses some positive cathode feedback.
| Cathode Biasing a 6L6 quartet power stage | Dave Z | Tubes / Valves | 2 | 7th February 2008 05:03 PM |
| cathode follower | vlljpior | Tubes / Valves | 6 | 22nd March 2005 07:50 PM |
| Question about direct coupling a anode follower into a cathode follower. | G | Tubes / Valves | 45 | 29th July 2004 06:47 PM |
| cathode follower | ackcheng | Tubes / Valves | 2 | 6th July 2004 03:12 PM |
| cathode follower | olvrkrg | Tubes / Valves | 3 | 21st February 2004 09:49 PM |
| Page generated in 0.09487 seconds (77.39% PHP - 22.61% MySQL) with 11 queries |
