Scrap or save? - diyAudio
Old 2nd September 2003, 11:34 PM   #1
Default Scrap or save?
I purchased this preamp off ebay a few months ago and it had a shorted transformer(one side). I replaced the transformer and it has a nasty hum in it. It consists of (3) 5814 Phillips tubes a solid state regulator and an adjustable B- supply. I was wondering if it is worth the time to try to solve the hum problem.
I will try to attach a schematic in wonderfull handcad.
Old 3rd September 2003, 01:33 AM   #2
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
Doesn't help that you used the same color as background
Tim
Seven Transistor Labs, LLC
Projects and Resources / Electronic Design and Consultation
Old 3rd September 2003, 09:37 AM   #3
dhaen is offline dhaen  Europe
diyAudio Moderator Emeritus
dhaen's Avatar
Tim
What, you mean black-on-black
Old 3rd September 2003, 10:37 AM   #4
I'll try this again
Old 3rd September 2003, 11:25 AM   #5
Ok, I finally got a picture to load but the quality is bad. You can however make out the channel on the right side of the page. It has a B+ of around 260 and a adjustable B- supply of about -65v to - 94volts. The bottom panel was missing from the unit and it looked like someone had tried to repair the unit. I am wondering if the unit might at one time had a Dc heater supply or am I just prone to playing with items exhibiting a higher than normal hum. All the grounds go to one point and the wires are twisted. I have tried moving the wires to different locations and have taken the pc boards and transformer out of the unit and set them on the bench as I tried to vary the hum level. Nothing helps. Any ideas? Should I junk it? The transformer I installed was a 250-0, 100-0, 6.3 volt.
Joe
Old 3rd September 2003, 11:25 AM   #6
dhaen's Avatar
Default That's better...
I think it's worth a try!
First of all, add 2 grid leak resistors to the inputs.
Old 3rd September 2003, 12:14 PM   #7
SY's Avatar
Second, start looking for ground loops. This circuit looks like it has a large number of potential places for hum to rear its ugly head. And about twice as many valves as you need, but that's another story.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 4th September 2003, 01:27 AM   #8
diyAudio Senior Member
fdegrove's Avatar
Third, scrap.
Frank
Old 4th September 2003, 01:38 AM   #9
Well, I added two grid resistors....hum still there. I looked for ground loops and checked all grounds and found no problems. Looks like it going to be headed for the scrap heap.
Joe
Old 6th September 2003, 02:31 PM   #10
Default Quiet now
On the way to the scrap box I decided to try one last thing. The heater winding didn't have a centertap so I added two 1% 90ohm resistors (didn't have any 100's)to ground and the hum left like a beaten stepchild. What was once a deafening hum is now gone. It is amazing how a 90plus db hum can be caused by this.
Was the preamp worth the bother? No, it sounds like something one might have purchased from Kmart at the bargain table.
The B- is adjustable by the way. Is this so you can zero the DC offset?
How can I make this sound better? I need to get a little more low end out of it. Any suggestions for coupling cap values? I have some .1/600 volt.
Joe
Mod it or scrap it? Aidan135711 Tubes / Valves 6 10th October 2008 04:09 PM
Scrap Heathkit W-5m for guitar amp? Tim Wyatt Instruments and Amps 3 23rd February 2005 08:00 AM
DIY scrap tubebuffer with ECC88 Mr. Triatic Tubes / Valves 12 8th August 2004 09:19 PM
Best Pass Amp Scrap A30 MikeW Pass Labs 10 2nd August 2003 09:37 AM
Copyright 1999-2017 diyAudio
