Scrap or save?
Scrap or save?
Old 6th September 2003, 02:49 PM   #11
fdegrove is offline fdegrove  Europe
diyAudio Senior Member
fdegrove's Avatar
Hi Joe,
The B- is adjustable by the way. Is this so you can zero the DC offset?
This is set to allow for DC coupling to the CFs.
How can I make this sound better? I need to get a little more low end out of it. Any suggestions for coupling cap values? I have some .1/600 volt.
Any idea what's in there for the moment?
100nF would be to low on it's own but you could try replacing the output loading R's to 100K if you have a pair.
Frank
Old 6th September 2003, 05:33 PM   #12
Burnedfingers is offline Burnedfingers  United States
Frank
Thanks for the reply.
I took out the 1mfd coupling caps and replaced them with what I happened to have. I could only find some .1/600v. The original caps were letting some good old DC thru. Shame on them!
Ok, what is the correct procedure to set the B-?
Joe
Scrap or save?Hide this!Advertise here!
Mod it or scrap it? Aidan135711 Tubes / Valves 6 10th October 2008 04:09 PM
Scrap Heathkit W-5m for guitar amp? Tim Wyatt Instruments and Amps 3 23rd February 2005 08:00 AM
DIY scrap tubebuffer with ECC88 Mr. Triatic Tubes / Valves 12 8th August 2004 09:19 PM
Best Pass Amp Scrap A30 MikeW Pass Labs 10 2nd August 2003 09:37 AM
