diyAudio Sponsor
Old 25th September 2011, 07:33 PM   #1
data is offline data  Australia
data's Avatar
Default Hyperx soft start any good for valve amp situation?
Hi guys
I have a secondary of about 440v and after full bridge rectification just a pair of Mundoff M-lytic HV caps effective 400uf/500v each that are rated for only 550v surge, would one of these Hyperx modules SOFTSTART - Hypex inrush current limiter - Europe Audio lower the potential 616v in-rush to something that these caps will be OK with?
I'm trying to avoid the extra caps in series, to avoid the lower capacity and higher ripple.
Or do I have no other option other than extra caps in series?
Speakers; Lenehan ML-1 - Amp; 25wpc El34 Custom - Phono; Boozhounds jfet - Turntable; Sansui SR838.
remote control(for amp or pre):soft start,on/off,volumn,4 input select(led display) uhcmos Swap Meet 3 25th September 2008 11:41 PM
Soft start & Dead time for TL494 ifrythings Power Supplies 9 18th May 2008 08:31 PM
Auto soft-start for class-T amp not working Nuuk Class D 23 20th June 2006 07:12 AM
soft start for amp/crossover jimbo1968 Chip Amps 6 24th November 2005 07:18 PM
Soft start & Soft Switch circuit: can anybody help? m.parigi Solid State 95 22nd August 2005 03:32 PM
Page generated in 0.05976 seconds (65.09% PHP - 34.91% MySQL) with 10 queries
