diyAudio Sponsor
Old 25th September 2011, 03:40 PM   #1
Default PP 6b4g bad / distorted channel diagnostics
Trying to diagnose one of the channels on a push-pull 6b4g amp, the amp uses 12sl7 and 12sn7 for the input and driver stages.
The symptoms are that the bad channel sounds "dirty" / distorted and is weaker than the other channel. The symptoms become more pronounced when the amp has warmed up for a few minutes or I turn up the gain control on the amp.
I'm far from an expert on tubes but I tried doing the following: swapped tubes, cleaned all tube sockets and pins with deoxit, cleaned the volume pot, checked resistors, looked for bad solder joints... all to no avail...
The amp isn't very old so I don't suspect that the caps would be leaking or be bad. I don't see any obvious leaks, bulging, etc. Unfortunately I don't have the equipment to properly test the caps.
Any suggestions as to what / where to look for the source of the distortion?
Old 25th September 2011, 03:59 PM   #2
A simple multimeter is enough to diagnose most problems. Simply measure voltages at various points, for example a leaky cap would result in a non zero voltage at the following grid (assuming cathode bias). Cathode, grid & plate voltages will go a long way to seeing if something is wrong.
Info for 6b4g PP sparkx Tubes / Valves 20 2nd March 2010 05:12 PM
Another PP 6B4G Ciscokid Tubes / Valves 3 24th July 2006 10:26 AM
help me design an input stage for 6b4G PP AudioGeek Tubes / Valves 11 2nd September 2005 07:48 AM
Help with 6B4G PP amp. AudioGeek Tubes / Valves 4 17th July 2005 02:53 AM
physical layout of 6B4G PP amp? zix Tubes / Valves 20 15th August 2004 09:43 PM
Page generated in 0.06142 seconds (70.76% PHP - 29.24% MySQL) with 10 queries
