| diyAudio Sponsor | ||
does anyone knows the sound difference between adjusting the
filament of an ECC82 6,3 V or 12,6 volt. and whats better to use and why? i have the possiblity to adjust the voltage between 6-13 volt must it be precise 6,3 volt or is 6 volt better.. |
#2 |
Mullard say 6.3V +-7%.
#3 |
No difference in sonic performance between 12.6V series operation across pins 4 & 5 or 6.3V parallel operation between pins 4,5 & 9. The required current is double for 6.3V operation obviously.. (ECC82/83)
In phono stages (ECC83) they may be operated on 11V (5.5V) at lower plate currents for reduced noise. They're quieter this way but I am not so sure about their performance otherwise. I prefer to run them as close to the nominal rated filament voltage as possible, and when using dc heating with certain Mullards it is a good idea to use some sort of current limiting during warm up. Don't ask me how I know this.
www.kta-hifi.net |
| how to adjust the filament power ecc83 | TBKK | Tubes / Valves | 10 | 1st March 2011 10:04 AM |
| Parallel vs. series filament supply - or another filament idea | engels | Tubes / Valves | 11 | 13th May 2007 01:06 PM |
| ECC82 | BJK | Tubes / Valves | 6 | 24th April 2006 02:51 AM |
| KT88SE with ECC82 | sith | Tubes / Valves | 16 | 5th January 2004 01:24 AM |
| ECC82 with GC | sith | Chip Amps | 0 | 20th November 2003 06:01 PM |
| Page generated in 0.06602 seconds (68.16% PHP - 31.84% MySQL) with 10 queries |
