| diyAudio Sponsor | ||
Medium size OPTs, silvery grey end bells, numbers 200A1 and 549821 stamped in very small letters in the end bells. Medium size, PP, UL taps, definitely old, cloth insulation on wires.
Would appreciate any info, particularly specs. |
#2 |
Bump.
#3 |
I guess you could work out the turns ratios by applying 110VAC to the primary and measuring secondary AC voltages, impedances are the square of that ratio with 8R load. Very likely though they match EL84's /6BQ5's or EL34's/6CA7's going on the UL taps, size should indicate which. rgds, sreten.
There is nothing so practical as a really good theory - Ludwig Boltzmann When your only tool is a hammer, every problem looks like a nail - Abraham Maslow |
#4 |
#5 |
Probably better to use a lower AC test voltage from the secondary side of a power transformer - as some people may think that they could use the AC mains as a test voltage, which would not be a good suggestion at all.
Ciao, Tim |
#6 | |
Same issues as testing mains transformers, if they work no issues.
#7 |
Guys, I did measure the impedance, that's not what I'm asking, but thanks anyway.
I want the spec sheet. OK, after much search I determined 549 is the code for Midwest Coil & Transformer Company. The last 3 are the date, the 21st week of 1958, 1968 or 1978 (the "8" digit). Now with this info, does anyone have any info, catalogs or links to same for the specs on this particular transformer? Thanks. |
| Please Help ID this... Diode? | jmlandry | Solid State | 10 | 3rd June 2010 03:07 AM |
| Help ID some old caps | JammyBStard | Parts | 12 | 23rd May 2010 04:27 PM |
| Tube ID anyone? | ectobia | Tubes / Valves | 2 | 25th February 2008 02:33 AM |
| trying to id some speakers | damianl | Multi-Way | 10 | 3rd January 2008 01:44 AM |
| Please help ID this: | martioz | Everything Else | 0 | 27th June 2006 04:34 AM |
| Page generated in 0.08568 seconds (76.97% PHP - 23.03% MySQL) with 10 queries |
