diyAudio Sponsor
Old 23rd September 2011, 08:23 PM   #1
ericj is offline ericj  United States
ericj's Avatar
Default Help? 6n23p cathode follower
I recently bought a pcb to build a hybrid tube/chip power amp. 6dj8 type cathode follower buffer feeding a pair of lm3886. Clearly the tube buffer is meant to add warmth and even-order harmonic distortion to the chip amp. My supposition is that the tube is meant to be nearly unity gain.
The relevant portion of the schematic is attached. (What? I can't attach photos?)
The designers, since they are chinese, designed around the chinese 6n11 tube. I can't find curves for this tube, but the vague internet rumors are that it's a chinese 6n1p, which would mean that it's pin compatible with a 6dj8 type but not really a 6dj8.
I've no intention of buying a 6n11 for $15. I have some 6n1p, 6dj8, and 6n23p here. I'm hoping that the 6n23p is a good choice for this application.
I've built a few valve amps based on other peoples designs but i am still essentially a tube dunce. I'm capable of not killing myself with high voltage but i don't know how to calculate the resistor values around a tube to set the operating point.
So, here is where i ask for help: Assuming that a 6n23p is a good match for this application, what are the ideal resistor values for R7, R8, and R9 at 90vdc b+? What should i consider adjusting if B+ turns out to be closer to 80v or closer to 100v?
Would i be better off with a more run-of-the-mill 6dj8 type? I've heard that 90v isn't really a great voltage for the 6n1p.
Old 23rd September 2011, 10:38 PM   #2
ruffrecords's Avatar
Some simple math should get us in the right ball park. With a 90V supply you want the cathode to be around half that for maximum output swing - say about 45V. With 33K in the cathode lead the tube current is not likely to be much more than one milliamp (45/33) which is way too small for a 6DJ8 in a cathode follower. You should aim for something like 10mA so you could change the 33K to 4.7K. Trouble is, looking at the 6DJ8 anode curves, that would mean a rather low grid bias voltage mainly because the voltage across the tube is so small. So let's try 5 mA instead and use a 10K resistor. from the anode curves, 45V across the tube and 5mA current requires a bias of -1V - that's more like it. We now need to change the 470R resistor to drop 1V at 5mA - R = V/I =1/5m (K) = 200 ohms.
So try changing the 33K to 10K and the 470 to 200 ohms for a 6DJ8. The 6N23P is pretty close to this so the same values should work.
Cheers
Ian
Ian
Old 23rd September 2011, 10:58 PM   #3
ericj's Avatar
Thanks for the suggestion.
I should have also asked for a pointer to a good website or book to learn more about this stuff, in terms that someone bad at math can understand. I've seen recommendations for Morgan Jones' book more than once - would you agree that it's a good place to start?
About the b+ -- the schematic doesn't specify it (I added that) but the board is configurable for either 65vac tube supply (= about 90 volts after rectification and smoothing) or to use the full wave of the dual supply for the chip amp.
I have selected a 25-0-25-0 toroid for the chip amp supply which would give me about 70v, which is almost certainly too low, so I am considering an off-board voltage doubler on the top half of the AC giving me closer to 100-105v.
It sounds as though i would not likely have to adjust your suggested resistor values for 15v greater b+. All the HV caps on the board are rated 160v so i have no worries there.
Old 23rd September 2011, 11:35 PM   #4
SY's Avatar
+1000.
Also see the cathode follower article ("The Heretical Preamp") on my website.
SYclotron Audio The Heretical Preamp
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 24th September 2011, 12:13 AM   #5
ericj's Avatar
Wait. R9 in the above schematic is 470K - corroborated by the BOM and the printing on the pcb.
Did you mean 200R or 200K?
Old 24th September 2011, 12:35 AM   #6
SY's Avatar
I think he was talking about R7 and R8.
Old 24th September 2011, 12:37 AM   #7
ericj's Avatar
then where did he get 470 from?
Old 24th September 2011, 12:40 AM   #8
SY's Avatar
Easy to misplace numbers on a schematic. In any case, use his suggested resistor values in the cathode circuit (R7 and R8). The grid resistor is less critical, it can be anywhere from 10k-1M. It's bootstrapped in this circuit, so you can make the coupling cap a lot smaller if you keep the 470k grid resistor.
Old 24th September 2011, 01:00 AM   #9
ericj's Avatar
ok, makes sense i guess
Old 24th September 2011, 06:06 PM   #10
I did not mention R9. I was talking about the 330 ohm resistor R7 which I mistakenly wrote down as 470. My apologies. There is no need to change R9.
And by the way, Morgan Jones book is ideal for beginners.
Cheers
Ian
Ian
Cathode Follower ideas please..... losacco Tubes / Valves 5 7th August 2010 11:22 PM
cathode follower vlljpior Tubes / Valves 6 22nd March 2005 07:50 PM
Question about direct coupling a anode follower into a cathode follower. G Tubes / Valves 45 29th July 2004 06:47 PM
cathode follower ackcheng Tubes / Valves 2 6th July 2004 03:12 PM
cathode follower olvrkrg Tubes / Valves 3 21st February 2004 09:49 PM
Page generated in 0.11965 seconds (81.85% PHP - 18.15% MySQL) with 10 queries
