diyAudio Sponsor
Old 23rd September 2011, 08:12 PM   #1
Bengali is offline Bengali  United States
Default DC Heater Caps
I saw some inside photo of a BAT tube preamp.
They use tons of capacitance in the thousands range.
These are for DC heaters I assume?
What is the reasoning behind these large capacitance caps for?
Old 23rd September 2011, 09:33 PM   #2
astouffer's Avatar
The more current you draw the more ripple the caps have to filter. Having DC on heaters with lots of ripple is worse than AC by itself.
Old 24th September 2011, 12:29 AM   #3
from some of the diy stuff, tube pre's, the cap values are generally around 1000uF-4700uF for 2 or 4 tubes.
the retail unit looks like is has 47,000uF or more.
Old 24th September 2011, 11:29 AM   #4
DF96 is offline DF96  England
Some people think that if a big cap is good, a bigger cap must be better. Not always true.
dc heater supply help milen007 Tubes / Valves 17 21st February 2009 07:42 AM
DC Heater Voltage Bengali Tubes / Valves 9 2nd February 2009 04:19 AM
referencing DC heater to B+ jarthel Tubes / Valves 4 28th March 2007 02:43 AM
Diode for DC heater dsavitsk Tubes / Valves 16 2nd January 2007 04:13 AM
AC or DC Heater? sauuuuuce Tubes / Valves 2 27th October 2004 12:57 PM
Page generated in 0.08503 seconds (67.56% PHP - 32.44% MySQL) with 10 queries
