diyAudio Sponsor
Old 23rd September 2011, 06:29 PM   #1
Default Amp project help needed
I have a couple of Peerless 16458 output transformers I'd like to use in a new project. I don't really want to redo a W5 Heath, so I was thinking of a 6B4/6A3 PP or a 6550/KT88 single ended amp. Would these outputs be suitable? Any thoughts or schematics greatly appeciated.Thanks for any help!
Old 23rd September 2011, 07:04 PM   #2
vinylkid58's Avatar
Why not?
jeff
Old 23rd September 2011, 09:46 PM   #3
Nothing against the Heath W5, just would like to try something different that others have found to their liking.
Old 23rd September 2011, 09:51 PM   #4
Frank Berry's Avatar
If it's a push-pull output transformer, you can't use it in a single-ended amp.
Frank
Old 23rd September 2011, 09:53 PM   #5
kevinkr's Avatar
The transformer is not suited to SE applications at all. Those transformers are worth a great deal of money and selling them would probably pay for an entire Tubelab SSE amp or possibly even a Tubelab SE..
Alternatively you could build something with KT88 using a different topology than the W5 which IIRC was somewhat noted for instability.. You could probably do something similar to a Citation II for example..
www.kta-hifi.net
Old 23rd September 2011, 09:55 PM   #6
vinylkid58's Avatar
Well, if I had a stash of 6B4G's, I'd probably build something like these:
6B4G Push-Pull Amp
heff
Old 23rd September 2011, 10:38 PM   #7
6B4G Push-Pull Amp
heff
That amp by Millet is one I've been looking at. Would the W5 transformers be a good match?
Old 23rd September 2011, 11:13 PM   #8
vinylkid58's Avatar
Not the best match if you're trying for max. power from PP 6B4G's. They were designed for a completely different tube.
jeff
Newby project idea for HND main project help and advice needed please WIGANWEZ Chip Amps 1 17th September 2011 04:59 PM
Newby project idea for HND main project help and advice needed please WIGANWEZ Chip Amps 0 17th September 2011 01:39 PM
good amp project needed nbcd Solid State 15 16th February 2009 03:03 PM
Father & Son project almost ready, XO help needed AllCaster Multi-Way 2 4th December 2004 03:18 PM
Parts needed for 3A amp. project NerdMike Swap Meet 0 20th August 2002 01:25 AM
Page generated in 0.09827 seconds (76.05% PHP - 23.95% MySQL) with 10 queries
